300M Overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2012, 10:04 AM
300M Overheating
My Chrysler 300M has a tendancy to run too warm. The thermostat has been replaced (twice) and the radiator has been replaced. I've been ensured that the head gaskets are just fine.
Anyone else have this experience and if so, how was it corrected?
Old 08-29-2012, 07:39 PM
bigdog7373's Avatar
Of course it's fast
Worked on a magnum, same basic design, and the fans werent coming on. Or maybe only 1 was coming on. But yea, make sure they both turn on when it warms up
The Following User Says Thank You to bigdog7373 For This Useful Post:
mgmayer (09-04-2012)
Old 08-29-2012, 09:17 PM
same here
Seems everyone wants to throw in Tstats without checking for the real problem. Like mentioned above. Make sure the cooling fans are coming on when they are supposed to. Also make sure the shop didn't add too much water when refilling your coolant system. I know anti freeze only raises the boiling point and NOT make any vehicle run cooler. Keep in mind water boils at 212, and most fans do not run until 232. So the cooloant boils over B4 the fans are designed to even turn on. BUT you didn't mention if it was boiling over or not. Chryslers are also a real Pain in the keester to bleed all the air out of the coolant system as well. Some shops don't even know how to bleed the air out. Hope this helps ! Lets hope they are correct in that your head gaskets are OK. The cars not worth fixing in most cases if they are.
The Following User Says Thank You to edspring1 For This Useful Post:
Old 08-29-2012, 09:26 PM
You don't say miliage. If this is a high miler you may want to run pressure tests on your CAT ( Cats). A Plugged catalytic converted or muffler will give you a overheating problem.
The Following User Says Thank You to boothboy For This Useful Post:
Old 08-29-2012, 10:05 PM
Wiki Edits: 31
Probably the water pump. They should be changed with the timing belt on that engine ( 3.5 unless I'm mistaken ). Factory pumps used plastic impellers.
The Following User Says Thank You to matt167 For This Useful Post:
Old 09-04-2012, 07:31 AM
Thanks for the replies, I do appreciate it.
Should have mentioned, it's a 2004 with about 78,000 miles and has been very well cared for....meticulously.
If I was to make a bet, I would put my money on the fans. It is so darn inconsistent and tends to run cooler when the A/C is turned on.
I am going to check with the shop and see if there is a way to 'override' the fan(s)...thus, have them run continuously. If it stays cool, that would answer that question.
Any idea if this is possible?
300m, overheating
Chrysler 300m overheating 1-bassman Engine 21 01-09-2012 07:10 PM
retired pro driver/now have to work on my stuff?1999chrysler 300m overheating ? Barthalemew General Rodding Tech 2 04-21-2011 03:36 PM
2000 Chrysler 300M Overheating problem.. mmgibbs1 Engine 5 10-19-2010 10:11 AM
Chrysler 300m 2002 3.5l RON MILLER Engine 7 08-13-2009 09:17 AM
2003chrysler 300m brake problems cliff tate Suspension - Brakes - Steering 0 01-12-2006 09:27 AM
