300m vs aluminum - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 05:24 PM
300m vs aluminum
Im really interested in seeing #'s but if anyone could give me a general weight difference between the two rods, and roughly life expectancy of either. Low CR street driven high rpm (7,000-8,000) I was told that a set of new aluminum rods could last up to 100,000 on street
Old 10-19-2012, 06:48 PM
Old & Furious
Yes they will last if setup right. But low compression engine is going to have issues going 8K rpm. That type fo rpm requires vacum pumps and full windage and scraper dry sump oil pans.
Most H beam rods will take that kind of abuse for a street car. Since you wont be running max rpm sep for once in a while. It is cheaper to run the heavy strong stuff than the super light stuff. Both will take the rpm. HP can be different a lot of power will take some planning.
Old 10-19-2012, 07:02 PM
I guess I meant to say not super high.
Old 10-19-2012, 07:27 PM
the aluminum rods won't spin higher? They will spin quicker right?
Old 10-19-2012, 08:23 PM
vinniekq2's Avatar
do not use aluminum rods on the street.no need.a steel rod motor will spin 8k easy
Old 10-19-2012, 08:39 PM
What's a safe CR for aluminum rods
Old 10-19-2012, 08:57 PM
vinniekq2's Avatar
aluminum rods in race engines,nothing to do with CR
Old 10-19-2012, 09:08 PM
They obviously aren't going to handle as much as a 4340 h beam. There has to be a Max cr. I realize no good for street, this is a seperate question.
Old 10-19-2012, 09:21 PM
vinniekq2's Avatar
no CR limit for using aluminum rods
300M Overheating mgmayer Hotrodding Basics 5 09-04-2012 07:31 AM
chrysler 300m overheat problems jayster Engine 1 02-23-2012 07:11 PM
Chrysler 300m overheating 1-bassman Engine 21 01-09-2012 07:10 PM
Chrysler 300M radiator removal barnesbd34 Engine 3 05-16-2011 04:10 PM
Chrysler 300m 2002 3.5l RON MILLER Engine 7 08-13-2009 09:17 AM
