302 in a 1989 ford ranger - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: can i put a 302 in a 1989 ford ranger
yes 15 88.24%
no 0 0%
don't know 2 11.76%
Voters: 17. You may not vote on this poll
Old 07-18-2006, 09:38 PM
I need advice on how to put a 302 c.i. in a 1989 ford ranger that currently has a 4 cylinder in it. I just want to know if it can be done or not but if it can are there kits or anything like that I would need to purchase???.
Old 07-18-2006, 09:55 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: Taking a short break
Here are two places you can read about such a swap:
http://www.v8-ranger.com/
http://www.mre-books.com/ranger.html
There are tons more online.
Strummin
Old 07-18-2006, 10:06 PM
lookatme's Avatar
sure can. a guy in my area did it, used the motor mounts, and tranny mounts out of the 5.0 that he pulled the engine from. but from what i recollect of what he said it all pretty much bolted in( ford had the 2.3L 4 mustang, and that swap is real common), the springs wi'll sag a little bit, and it wont take corners as great, but otherwise no probs. good luck
chris
Old 07-19-2006, 03:54 PM
Kruzin Karl
http://www.rangerpowersports.com/tech/?cat=6
Check this out, lots of info there.
Old 07-19-2006, 05:24 PM
KA67_72's Avatar
I have a 302 in a Ranger. I used a truck EFI intake so I had to remove the AC. I'm a Chevy guy at heart, but one of the advantages of a Ford is easy motor mounts. I took two 3/16" plates about 4" wide and drilled them for the bolt holes to the block. With a dual sump pan ($25 off ebay), and a remote oil filter kit, those plates sit right on the frame rails. I welded them to the frame rails and made a couple of pieces to triangulate them. I didn't have the rotating assembly dynamicly balanced, but I balanced the pistons and both ends of the rods to within 0.05g. There's no vibration through the solid mounts. Then I made an offset bracket for the trans mount. I had to lengthen the driveshaft. My donor for the 302/C4 was a Granada. The front 10" or so of my driveshaft is Granada, the rest is Ranger. I don't know how much you want to spend but I paid 200 for the truck, 200 for the Granada, and another 2100 in parts and paint.
There are pics and a short video of it running poorly when we were trying to figure out tuning the efi in my pics.
Have fun,
Kevin
Old 07-19-2006, 05:42 PM
hotrod fozzie's Avatar
REAL HOTRODS have FLAMES!
yep
jegs.com sells the motor mounts, headers and i think rad you will need
My dad and I did it with a 350 chevy and a 1983 ford ranger back in 1992
it fit all but the dist. hit you won't have that problem with a ford dist. in the front of the motor.
Old 07-19-2006, 05:54 PM
check out ----therangerstation.com
they can help you out I'm a member there got a lot of ranger things there great place join you like it.
Old 07-19-2006, 09:31 PM
cabowabo's Avatar
big Q
302 in a focus
get a wreck focus and swap a 302 in it
Old 07-19-2006, 10:32 PM
302 focus
have you ever put a 302 in a focus because the more i think about the more i like it
Old 07-20-2006, 04:59 AM
KA67_72's Avatar
V8 Focus conversion:
http://www.kugelkomponents.com/focus/focus.html
Old 07-21-2006, 11:48 AM
there's seriously a website for that
Old 07-21-2006, 03:12 PM
Siggy_Freud's Avatar
It can be done . A guy I know (although I wouldn't call him a friend) had a truck with a 302 in it. Someone else drives it now.
Bringing history and technology together.
302 in a Ranger? Rodder318 Engine 5 08-24-2007 06:57 PM
97 4WD ranger needs a 302 chevelle_502 Engine 0 07-16-2004 06:49 AM
1989 Ford Ranger V-8 Engine Swap Pontiacman Engine 1 05-30-2004 08:39 PM
1989 Ford Ranger 4x4 conver. Pontiacman Engine 1 04-03-2004 12:43 PM
Trailer Towing w/ 2000 Ford Ranger nightrain_rod Transmission - Rearend 17 06-25-2003 06:07 PM
