302 to 351 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2002, 12:00 AM
New Member
Post 302 to 351
I have a 1970 302 Windsor engine and I want to change to a 351 Windsor, I have a 1974 351 Windsor block but it doesn’t have a timing cover or harmonic balancer. Can I use the timing cover and balancer from the 302 on the 351? Seems like I should be able to use them but its better to ask someone who knows than take a chance.
Old 10-26-2002, 04:50 AM
woodz428's Avatar
Troll Hunter
Post
Unfortunately, no. The timing cover fits but the oil pan sealing surface has a smaller radius than the 351, so won't seal properly. The harmonic balancer is where Ford puts the balance weight for the engines (external balance) and the 351 has a heavier rotating assembly.
Old 10-26-2002, 06:26 AM
48fordnut's Avatar
Post
I have used the timing cover numerous times and there was never a problem. It is not the weight of the assy but the balance, you will have to use a 351 balancer.Also when you get the balancer try for the pulleys as the early ones are 3 hole and the later ones are 4 hole.
Old 10-26-2002, 06:43 AM
New Member
Post
Thanks guys for the information, seems like it is unanimous that the balancer won’t work, but a little hazy about the cover.
Old 10-26-2002, 08:23 PM
mustang66maniac's Avatar
Ford Freak
Post
the cover will work, i've done it before.
I thought that the balancer would work. 351s have a 28 ounce balance and so do early 302s. (not after 82) Isn't that all that matters?????
Old 10-26-2002, 10:16 PM
New Member
Post
Thanks mustang66maniac, I believe that is all that matters. I will give it a try and we will see what we will see!
