302 or 351w or 351m or 351c?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2002, 11:38 AM
Post 302 or 351w or 351m or 351c??????
now looking at a car i just bought how can u tell the difference between a 302 and a 351w because they are the same blocks im confused to tell and if u just looked at a engine sitting there (a 351) how can u tell whether its a cleveland, a modified or a windsor????
Old 06-02-2002, 12:36 PM
Post
The first post I made was not the correct way the site works. Sorry. Johnny
[ June 02, 2002: Message edited by: johnny 1986 ]</p>
Old 06-02-2002, 12:44 PM
Post
sorry
its 2 questions put into one ok?
Post
[quote]Originally posted by shagginwagonvic:
<strong>now looking at a car i just bought how can u tell the difference between a 302 and a 351w because they are the same blocks im confused to tell and if u just looked at a engine sitting there (a 351) how can u tell whether its a cleveland, a modified or a windsor????</strong><hr></blockquote>
The 302 and 351w are often times thought to be the "same" block. The fact is they are not. The 351w has a deck height about 1 inch taller than the 302/289. Another "quick" way to tell is the 302 intake manifold is aproximatlly 7 1/2 inches wide, while the 351w is 9 1/2 wide. The clevland looks a lot like a 460 if it is a fairly late model and has factory valve covers. The "M" moter can usually be identified by numerous oil leaks and sludge and grease everywhere. Hope this helps you out. Johnny
Old 06-02-2002, 03:33 PM
FASTFORD's Avatar
Post
i agree,measure the intake for 302/351w. the 351c and m`s are easy to verify,the thermostat housing is seperate from the intake and points up.also the valve covers have 6 bolts on 302/351w 8 bolts on 351c/m.
firing order for 302 is 1-5-4-2-6-3-7-8
order for 351w is 1-3-7-2-6-5-4-8firing order for 82 and later 302ho is same as 351w
351w is 3 inches taller than 302 and 2" wider
i hope this is what u needed. fords rock!!!!
