302 with 351w heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2011, 11:03 AM
302 with 351w heads
Hello guys and girls, I have a few questions. I'm more of a Chevy guy, do a lot of Chevy builds, and do some Ford builds from time to time, mostly in the FE class, and a few small block stock-type rebuilds. However, a customer brought me a 302 block, with a set of heads that have "302" in the casting under the valve covers, which they assumed were 302 heads. I did a little research on the actual casting numbers, which were D00E, and turned up they were actually 351w heads. Is this correct? I called the customer back to let them know they are not the correct heads for the block, but they asked if I could make them work anyway.
I've been doing some research online, and I've been getting conflicting reports. Some say the D00E head will not work on a 302 block (D20E block), others say it will but requires a modified intake manifold.
So I figured I would come to hotrodders.com. I've gotten a lot of good info from you guys in the past from searching the forums. This time I thought I would actually speak to you instead of lurking in the shadows.
What is it going to take to mound these heads (D00E) to the block (D20E)? Any special head gaskets, bolts, intake, intake gaskets, etc?
Also, does anyone have any specifications as far as chamber sizes on these heads?
Thanks everyone. Any help would be greatly appreciated.
Old 01-10-2011, 12:08 PM
Irelands child's Avatar
351W D0OE heads will work on a 302 and are a good choice as they have larger valves. The only thing you will need to do is supply bolt hole bushings, available from Summit for not very much - 302 have 7/16" head bolts, the 351W have 1/2" head bolts. The 302 intake will bolt directly to those heads. You will need the correct gaskets though - and Fel-Pro's will work
Head bolt bushings = http://www.summitracing.com/search/?...bushings&dds=1
Fel Pro gaskets = http://www.summitracing.com/parts/FEL-1250/
Take a look in the exhaust port. Some/most of these D0OE heads had an EGR 'hump' - get your die grinder out and smooth it to the shape of the rest of the runner without taking an excessive amount of material off. Don't worry if there is still a hole, it wont hurt a thing.
Pull the press in rocker arm studs then tap 7/16-14 and install and install screw in studs. The hole is the correct size as you remove the originals. These are the same studs as SB Chevys use.
http://www.summitracing.com/search/Part-Type/Rocker-Arm-Studs/Base-Thread-Size/7-16-14-in/Make/FORD/?Ns=Rank|Asc
Now - you have a set of as good an iron head as Ford made until the GT-40s arrived.
Now - with them having 302 cast under the rocker cover.....?? If indeed they are a 302 version, they should already have 7/16 head bolt holes, but Ford in the '60s - '80s did some real off the wall stuff.
Dave W
Old 01-10-2011, 12:27 PM
Thanks Dave. Have you by chance ever seen a set of D00E heads in a 302 version? It's a large "302" casting, that's for sure.
Old 01-10-2011, 01:31 PM
I have not - they have all been off 351's. I even trashed a set off of a 351W a while back in the metals dumpster at the dump. Just check the head bolt holes. If they are for 7/16 bolts - you are GO as an original 302 item. Like I said before, Ford did some real strange things in the early days of "W" engines. Just watch intake coolant holes
There is one thing that these D0OE heads don't have - hardened valve seats. Then of course, valve guide wear is probably out of spec on any with high mileage heads.
If your customer can find a set of GT40P's from an Explorer or Expedition, then it's an even better choice - until you try to find headers .
Whichever heads except the OEMs will each have a different set of interesting problems to work around, but all "W" heads except that odd ball 255cid will interchange tho you do have to consider compression ratio with the smaller displacement versions under the 302/5.0L
Dave W
Old 01-10-2011, 04:13 PM
I found a half-inch bolt, actually it was just under @ .490", and it would not fit the head bolt holes. So I'm guessing these are 302 heads. Strange.
I like Chevy's casting numbers. Much easier, in my opinion!
Old 01-10-2011, 05:52 PM
Does anyone know how to identify these heads as 2v or 4v?
Old 01-10-2011, 05:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Ford did have DOOE-B casting for 302. JMO
Cole
Old 01-10-2011, 05:59 PM
Cole
Glad you came up with that Cole - as I have seen maybe a dozen or more D0OE's and all from 351W's
And as far as 2/4 bbl - they are the same
Old 01-10-2011, 06:55 PM
They didn't make a 2V or 4V model of these heads?
Old 01-10-2011, 07:00 PM
eloc431962's Avatar
Wiki Edits: 37
The heads are the same they did put out some 4v 302 engines but the heads are the same on the 2v version and the 4v version. As Dave stated.
Cole
Old 01-10-2011, 07:29 PM
So I take it the only difference was the intake and carb then, correct?
Old 01-10-2011, 07:44 PM
Wiki Edits: 27
runner flash
Ford tried to get as many miles (parts) as possible using the casting pattens to save money, Feel inside the ports for casting flash and mismatch at the parting lines. and just smooth out the intake and exh ports unless you know how to reshape . on some engine just doing that makes a big difference , the stock ford Long Body 4 bbl carbs also had casting mismatch in the bores, smothing those also helps a lot.
Old 01-10-2011, 09:45 PM
mud.man.rj's Avatar
F O R D
Ford sure can require a lot of thinking compared to Gm.
Old 01-11-2011, 06:40 AM
Consider it a "thinking mans' engine then. You can pick up a dozen books, guides, etc., talk to your neighbor or his kid and build a SB Chebbie that will run OK. But, the SB Ford W or C, you do have to consider parts, but when you are done, it will run better then OK
Old 01-11-2011, 07:30 AM
eloc431962's Avatar
Wiki Edits: 37
You got my vote Dave. I totally agree.
Cole
351W heads on a 289/302 kleen56 Engine 8 06-30-2008 09:31 PM
351W heads shiftless Engine 11 09-28-2006 10:50 AM
Are 351W and 302 heads the same? Kruzin Karl Engine 4 09-02-2006 03:44 PM
351w heads on a 302? Arrowhead Engine 4 09-26-2004 10:42 AM
