302/5.0 SB Ford pan gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2008, 11:06 AM
Irelands child's Avatar
Are there any secrets to installing a one piece oil pan gasket that I should know. I'll be installing one this afternoon, replacing a cork version with separate end seals has been seeping. Except for the fact that the @#$% thing has to be tied/taped in place and the little seal ears need to be slid up in their fit, I don't really see a problem - except for the fact I'll be laying on my back with oil dripping on me and my specs.
(Wish that I had done this gasket when the engine was on the stand and upside down )
Dave W
Old 08-13-2008, 11:37 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Dave
I use a bit of permatex to glue the thing in place then put the pan on..Weatherstrip adhesive works in a pinch as well..Any way some sticky stuff to hold the gasket while you get the pan into place..
Sam
Old 08-13-2008, 12:00 PM
Sam,
I'd use the Permatex on the old cork style (probably contact cement) but this is one of those fancy gaskets - with the raised sealing ridges like a blue Fel Pro head or intake gasket. From the Motorsport catalog:
"M-6710-A50** 5.0L
Designed for use with
smooth rail oil pans.
One-piece design, rubber
bonded on steel reinforcement.
Fits 1983-01 block/oil pans with
dipstick in the block."
Oh well, out comes the contact cement - it always works to hold a gasket in place - sometimes too well
Dave W
Old 08-13-2008, 12:17 PM
sbchevfreak's Avatar
Licenced Automotive Technician
IDK about the Ford one piece, but the fel pro's come with plastic "snap up" studs for just this purpose. I try to keep every set that I get, 'cause you never know when you'll need them.
Old 08-13-2008, 12:31 PM
Not sure what "snap up" studs are. The Motorsport gasket I have has a couple of tabs on each end that slide up into the block - which are similar to the original seals, and I'll be willing to bet will be a PITA for me in about 10 minutes when my contact cement sets. I am using some studs for locating this gasket while I bolt it in place.
Dave W
DONE - amazing what contact cement can do for your car stickum needs. I would have been done 10 minutes faster except I forgot the pan rail supports - now if it doesn't leak......
Oil Pan Gasket 71 c-10 Engine 7 10-31-2007 03:23 PM
79 Ford Courier oil pan kringold Engine 6 10-28-2007 08:47 AM
I cannot get my oil pan gasket to seal undy Engine 2 05-12-2006 05:21 PM
One piece sbc oil pan gasket? jtybt Engine 1 04-26-2006 05:33 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
