302 In a 67 mustang acting like it's hot - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 02:38 PM
OK I got a 302 In a 67 mustang... Temp gauge says the motor is cool but if it runs for about 20 30 mins it starts acting like it wants to die due to it getting too hot! Thermostat is good put it hot water watched it open my oil gauge is not wrkin but I think the pump is wrkin cuz its not makin a bunch of noise!! PLEASE HELP IF U CAN?
Old 11-18-2012, 02:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How long since the cooling system has been flushed..had that issue and needed to have the radiator cleaned and flushed as well as the engine..those can build up deposits in the cooling system which will cause your difficulty..
Sam
Old 11-18-2012, 02:55 PM
poncho62's Avatar
Wiki Edits: 5
You said the temp gauge is reading normal.....How do you know the engine is overheating?...Is it spitting water out, boiling over?..or is it just running bad after 20 minutes?
Old 11-18-2012, 03:07 PM
techinspector1's Avatar
Wiki Edits: 326
Check fuel pressure at the carb inlet. Adjust for max 5 psi. Re-set float to specs.
Old 11-19-2012, 01:04 PM
If the pump is making noise it could have air in the system. Also could be cavitation. A block in the system will cause this. A cooling system not bled properly can cause "hot spots" near the head.
Old 11-19-2012, 06:13 PM
Some of the new thermostats dont have the little piddle valve like they had before. It's a small hole with a metal inset that allows water to pass even if the thermostat is closed. If the thermostat lacks this, you can drill a 1/8" hole on the flat part.
Old 11-20-2012, 04:09 AM
bondo's Avatar
Ayuh,... What, Exactly are the symptoms it's displayin',..??
68 Mustang w/302 Stalling JParker77 Engine 4 10-11-2012 10:07 AM
302 acting wierd md70ss Engine 7 07-26-2011 01:44 PM
302 Swap in 69 Mustang vfr172pilot Engine 20 08-30-2007 11:11 AM
mustang HO 302 rockne07 Introduce Yourself 1 05-23-2007 05:35 PM
84 mustang gt 302 john s resch Engine 0 03-28-2007 12:11 PM
