It's rare that I see anything positive said about TCI, but without personal experience, I'll leave it at that. Check around for opinions on that one.
The AOD is a good choice if you know its weaknesses up front - the later the year, the better. The clickclick site is a goldmine. With overdrive, don't get lazy gears in the rear or it'll put you to sleep. 3.73 is a good combo although a shift kit/valve body WILL be needed to make it shift right - these use a governor/throttlevalve set up for granny gears and 3.73-4.11 screw up the shift points a bit. Transgo shift kits offer NO tuning and may or may not work as desired plus they offer ignorant "upgrades" such as overdrive at WOT which kills aods. Baumann kits look cheap out of the package but offer a good deal of tuning and simply WORK. For even better performance, if that's your thing, combine the Transgo Hi Rev kit with the Baumann - easy to do and really wakes up the shifting. Anyone interested, drop me a line.
