302-boss 302 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 02:31 PM
302-boss 302
I have a 66 mustang with a 302 in it i want to change my 302 to a boss 302 what parts and what work do i need to get done to do this
Old 08-18-2005, 02:52 PM
New Member
do you want to convert the 302 you have? or put in a 302 boss already assembled. the heads on the boss is really the only major outside change/look of the engine. so motor mounts and things of that sort will not matter. cleveland heads,boss pistons,boss intake,boss valve covers will be major parts you will need.
Old 08-18-2005, 03:16 PM
Rev It Loud, Drive It Proud!
boss
the rods are also a different length
Old 08-18-2005, 03:40 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cam Lobes
I'm pretty sure that 351C heads can be used on a "standard" 302, but the coolant passages in both the head and the block have to be modified. I think I saw that in a book called "How to hotrod your small-block Ford"
I agree with others who have posted on this topic when they suggest to go with aftermarket "bolt-on" heads. Ford Motorsports used to make some, I think.
Old 08-18-2005, 04:03 PM
aka Duke of URL
True 69/70 BOSS 302 heads do not have to be modified or is there a need for a special intake (only the actual BOSS intake is needed-and there were several variations).
Old 08-18-2005, 06:09 PM
lluciano77's Avatar
Short changed on common sense
Here is an intake:
http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
Here are some heads:
http://cgi.ebay.com/ebaymotors/ford-...QQcmdZViewItem
Old 08-18-2005, 09:03 PM
347mustang's Avatar
a real 302 boss bock is a 4bolt block..with a factory steal crank...and are high dollar pices...a clevland head can be made to fit..with a few drilled and plugged holes...which is called a cross boss...but unless you want to run a high rpm..the boss and clevland heads are way to big for a 302...ports are huge ..boss heads had 2.25 valves in 1969 and 2.19 in 1970..plus a boss 302 intake are hard to find..unless the aftermarket has started to make them.....than you have to have headers made to fit the car..
Old 08-18-2005, 11:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Build the Street Boss 302. Here's all you need to know.
http://www.mustangandfords.com/techarticles/30220/
How to ID a Ford 302 Boss unioncreek Engine 20 01-08-2006 12:20 PM
boss 302 shagginwagonvic Engine 5 09-29-2003 07:09 AM
change a 302 into a boss 302 amc Engine 3 08-25-2003 05:51 PM
Homebrew Boss 302 Busted Knuckles Engine 4 11-21-2002 12:55 PM
302 and 302 Boss 59Fairlane Engine 8 09-07-2002 05:31 PM
