302 build help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2007, 04:33 PM
302 build help
Hey all, been gone a little while as i had ot put one of my projects on hold ot finish up another (finished my 3.4L DOHC fiero swap...)
Anyways. The engine is a fox body mustang 5.0HO with factory forged pistons but it has been converted to carb using a 289 Torquer intake manifold. So far have not gotten a lot of mods done, but i will post everything i have done and plan to do.
Also the engine and trans (T-5) is in a 1990 Mazda RX7 so keep that i mind when i mention some stuff down further...
DONE:
-got rid of the A/C
-complete set of BBK underdrive pulleys
-dual remote mount oil filter kit with twin WIX filters
-hooked up to the factory RX7 oil cooler (23" X 5" X 2.5")
-NOS wet nitrous system running a 200 shot (cheater kit up to 300 shot)
-Fox body long tube headers (1 5/8" with 3" collectors)
-dual 3" exhaust from headers back to an x-pipe then out a mindtrain 2.5" dual "catback" exhaust (sold for about $2K new)
-gasket matched and polished heads(E6SE) and intake(torquer)
-ROL "race" head gaskets
To Do:
1.6 roller rockers
ignition system
Now i am looking for advice on a carb and ignition system. I was thinking a holley 600CFM. As for the ignition i was thinking an MSD 6-BTM, Pro Comp HEI coil, and a 50K/65K HEI dist. along with a good set of wires and plugs
I am still rinning the stock E7TE heads with the gasket match and polishing, stock cam as well, i will be putting in new lifters and pushrods, should i upgrade to roller rockers? if so just the 1.6 correct?
any suggestions?
Old 08-03-2007, 04:54 PM
techinspector1's Avatar
Wiki Edits: 326
Well, if you give up bottom with the manifold and top with the heads, what's left? Maybe it'll run pretty well at mid?
In my opinion, you should re-think your whole combination.
Old 08-03-2007, 05:32 PM
I am not going to pump anymore money in it than i have to because i am going to be building a 408W before too long... So far everything i have bought with transfer right over to the 408W. When that engine gets built i will be pulling the roller rockers off and getting a nice set of aluminum heads for it.
As far as rethinking everything... I pretty much have everything already except the ignition, carb and roller rockers. I know it isnt a great setup, but it is what i have laying aoround so i might as well use it for a little while... And i am going to spray the crap out of the engine as i am not too worried about splitting the block so it should run like a raped ape no matter what.
Old 08-04-2007, 09:35 AM
anyone have any more input?
Old 08-04-2007, 11:04 AM
DoubleVision's Avatar
If your using nitrous you need more cam. A open plane intake is for upper rpm performance, the stock cam is for low rpm torque and pretty much useless past 4000 rpm. If the engine can`t breathe it won`t make power no matter how much nitrous you spray to it as the cam will limit the amount it can take in. Fords suffer from a small kinked exhaust port, I would have focused my porting efforts on it. If the engine has a stock timing chain that has slack, then you`ll be spraying a time bomb. The 600 carb will work, and the ignition will as well. If you mean full roller rockers you`ll need to set up a magnet and screen system to keep stuff out of the oil pan when one comes apart. A roller tip rocker will only help if it has a higher ratio. Tech said what he did as the combo is lop sided, but it will work, just not as well as it should.
Clevor Boss??? matts94sc Engine 33 01-23-2008 08:51 AM
Some help with a 302 build mr.Pinto Engine 8 07-14-2007 03:36 PM
Outline to build a 32 54marko Introduce Yourself 1 07-09-2007 06:29 PM
can i destroke a 351 w with a 302 or stroke a 302 with a 351w? jims84gt350 Engine 5 04-02-2006 01:04 PM
