302 chev rod length? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2002, 04:54 PM
Post 302 chev rod length?
Just wondering the rod length of a 302 chevy. Would a 400 rod work in a 327? THANKS! Dave
Old 09-22-2002, 05:09 PM
Post
Standard lenght for a V8 Small block Chevrolet is 5.700 inches.
A 400 has a rod that is 5.565
A 400 rod could be made to work in a 327 with special pistons but WHY?
Old 09-22-2002, 06:25 PM
NAIRB's Avatar
Post
Connecting rod length is a subject that is considered to be "black magic" by alot of engine builders, and using longer rods is almost universally accepted to be the way to go. A longer connecting rod, with all other factors being equal, allows the piston to "dwell" longer at TDC, which allows combustion pressure to act upon it longer, which in turn creates more power. I have heard the short rod theory, that they produce more low in grunt, due to changing the angularity at which they meet the crank pin, but I think that's a bunch of bunk. Generally, shorter rods create more side-loading of the piston thrust surface, and increase bore wear. I would stick to 5.7 rods or longer with a small block chev.
