302 Chevy sparl Plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2005, 01:21 PM
I am building a z28 302 Chevrolet engine with mostly stock parts. The heads I am using are angle plug early version 202 heads. What plugs would I use for these heads with this engine?
Thanks
Mike
Old 06-06-2005, 02:11 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Any 5/8 reach gasketed plug will work.
Old 06-06-2005, 02:56 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Try the Accel 276
Old 06-06-2005, 03:00 PM
Old does not mean dumb
Hi, No gasket on those heads are required. Autolite #22 thru #26, Champ. #BL7y thru #BL17y and so on. The parts store can inter-change to the brand you want to use.
Old 06-06-2005, 05:39 PM
Spark Plugs
Thanks for the information I will try these out.
Old 06-06-2005, 06:45 PM
Heimbig, If your engine is 11.1 as original, you would want to stay on the colder side of the heat range. AC-43S were standard in mine, but they were straight plug. BL9Y Champion is the non resistor plug. The parts store can interchange to the brand you prefer. You would want to run a resistor plug on the street or if you are running an MSD type ignition.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
chevy 302 help jonny5.0 Engine 15 02-06-2007 07:11 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Chevy 302 doit Hotrodders' Lounge 3 05-31-2005 05:54 AM
chevy 302? minesblown Engine 4 10-08-2003 06:07 AM
