302 dies when I put it in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 12:04 PM
Senior Shadetree
I have a 1977 Mustang II with a 302, a mild cam, 4bbl carb, headers and an automatic transmission with a b&m kit. This past year it sat idle for approximately 7 months. Now, it will start, idle and runs well until I put it in gear. As soon as I put it in gear, it dies. I have drained the gas, put in Heet, ran carb cleaner through it and put in Sea Foam gas treatment. It will start when it is cold but after is dies, it won't start again. Could this be that the carb accelerator pump isn't working, OR WHAT IS IT?? Any suggestions on what I should do next??? Help!!!
Old 07-14-2012, 09:55 PM
The accelerator pump only has an effect when the throttle is opening. Stalling in gear is usually a symptom of a vacuum leak, which is entirely possible with an engine sitting idle for an extended period. Try disconnecting and the vacuum accessories (PCV valve, brake booster, etc) and see if it still does it - if it fixes the problem, it's probably a cracked vacuum line.
Dying in gear can also be a timing issue - if the mechanical advance comes in low enough that it's advancing at idle in park, the rpm drop in gear can cause the advance to drop out and retard the timing enough to kill the engine (I just went through this with my Mustang). Something to check, anyways.
Old 07-15-2012, 07:55 AM
Wiki Edits: 27
trans hose
also check the Vac hose to the trans and the modulator.
Old 07-15-2012, 08:19 AM
Senior Shadetree
I'll check out the suggestions and get back to the forum (when the temperature gets below 100). A vacuum leak makes sense. Maybe a mouse ate one while it was parked. Thanx for the feed-back. I'll let you know.
High idle and dies when put into gear hotrodtodd Engine 5 03-23-2012 06:21 PM
350 dies when put in gear 70C/10 Engine 6 10-28-2011 12:23 AM
SBC won't idle right and dies when put in gear multicar Engine 3 12-22-2010 09:52 PM
89 camaro dies when put in gear brownk2010 Transmission - Rearend 15 01-10-2010 11:28 AM
engine dies when put in gear starchief Engine 4 07-22-2003 07:35 PM
