302 distributor oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 08:08 PM
I have a 302 that has a nagging oil leak around the base of the distributor. I have replaced the intake gaskets, timing chain cover gaskets, valve cover gaskets, and the o-ring around the distributor. I have even pulled the distributor and checked that I didnt pinch or cut the o-ring when I installed it. Any suggestions anyone?
Motor is in a 65 Comet. Eldebrock Intake. Aluminium valve covers, Stock heads, distributor, timing cover.
Old 12-17-2005, 09:01 PM
TechnTool's Avatar
OldSchool MotorHead
Whenever I get an oil leak on an old engine, it seems that there is a slight indentation where the old seal sat. When I find this, I find out what type of seal wa originally used. On old engines, rope seals were used extensivly, and you may have to use an original type seal, instead of a modern replacement. You could also take the Oring and get a slightly larger one, and slick it down with aviation sealer.
Old 12-17-2005, 11:08 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Are you sure the source of the leak is the distributor?
How does changing all the gaskets relate to the distributor?
Surely you have a vented oil cap and a PCV on the engine so there is no pressure in the crankcase.
This is an extremely rare place to have an oil leak if there is no pressure inside the crankcase pushing oil out.
Like he said, a fatter O-ring might be what you need. Or you could put a dab of Aviation Permatex under the dist flange. But oil should not be getting above the o-ring.
Old 12-18-2005, 08:32 AM
re-torque the intake bolts,
it's way more likely that you don't have a (good silicone) seal across the front block top to bottem front of the intake manifold behind the dist
clean the whole area with a little carb cleaner, sprinkle some baby powder or similar, check to pin point the leak stain source
do you know the history of the block and heads (milled, decked, original?)
Old 12-19-2005, 10:08 PM
I dont know the history of the heads or block. The guy I purchased the car from just dropped it off at a mechanic and picked it up when he was done. He actully told me it was a 289 but as soon as I started checking numbers it was a 302. I have never heard of the baby powder trick. I will try that first.
302 vs 289 kidvid Engine 38 03-28-2017 09:09 PM
Bad Oil Leak,,, Help! Lthompson Engine 8 08-15-2007 03:33 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
302 or 351w nicowarrenrogers Engine 9 03-25-2005 07:15 AM
Chevy 302 purplenova Engine 6 10-25-2002 07:26 PM
