Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 302 engine build
Old 02-10-2013, 11:35 AM
327NUT's Avatar
327NUT 327NUT is online now
Just a little recommendation........before you buy anything, do a LOT of reading on the engine you decide on. You'll be money ahead from not buying a bunch of parts you either don't need or can't use. There are lots of books on "How to hot rod a small block Chevy" and the same for the small block Ford. The nomenclature used in the performance world is just like learning another language.
The Following User Says Thank You to 327NUT For This Useful Post:
benbee51 (02-13-2013)
