Assumeing ford 302. Ford 302s are famous for ppl putting lots of money into them and getting 240 hp back in the end. You will want clear goals and budget.
Best to search out a good build with dyno results and copy that success if at all possible. What year, car, race or street and goals. |
X2 with AP 72.
You can get a complete stroker kit to pump it up to 347 cubes. Very nice. Also GT 40 heads can be had for a little legwork and some change $$ Just find a 96-97 explorer with a 5.0 liter in it. Grab Dem heads Plent of good 303 grinds right from ford motorsports for a cam. Some of them alabama boys making gobs of horsepower on Passtime with - ahem - "mostly stock" 302 s ![]() LOL ![]() ![]() Welcome to HR . hang around , do some reading , ask some questions ...build something cool.
Fact is stranger than Fiction |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
benbee51 (02-10-2013) | ||
Thanks so much for the information. im just trying to find a good place to start. im at a lower than childs level in all this and just wanna learn the best way to go about it all. ive also been considering a 350 build. realized how easily i could find good short block to start from. Also if this is a reasonable question.... what would be a good vehicle to pull a 350 short block from? once again thanks for all the feed back. this website is really insightful.
If it has a carb on it I wouldn't even bother with it, if it has a TBI unit that's usually not worth much either. the TPI engines are decent but the LT's and the Vortec's usually have the best platform to start with- either can go over 400hp with just a cam swap and headers. |
| The Following User Says Thank You to ap72 For This Useful Post: | ||
throttle body injection- its where the intak emanifold looks basically like a carb manifold and you have a carb looking device with two large injectors sitting on top- it was a VERY common method of induction in the 80's-mid 90's. Its better than a carb but not nearly as good as MPFI (even if its batch fire).
BTW, MPFI = Multi-Port Fuel Injection...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
what are your power goals? If they're modest (400hp or so) then I would start with a COMPLETE RUNNING LT1. For just that short block I'd only give about $100, as putting it back together as a complete engine is going to cost more than buying a running engine.
This being my first build im really just doing it to do it, id love to maximize preformance but realistically 400hp could be acheivable.
Also hes asking $250 on ebay. ive still got lots more looking around to do. |
Just a little recommendation........before you buy anything, do a LOT of reading on the engine you decide on. You'll be money ahead from not buying a bunch of parts you either don't need or can't use. There are lots of books on "How to hot rod a small block Chevy" and the same for the small block Ford. The nomenclature used in the performance world is just like learning another language.
| The Following User Says Thank You to 327NUT For This Useful Post: | ||
benbee51 (02-13-2013) | ||
Get a complete LT1 take the heads off, port them, get a good valve job, mill off .030" port the intake and throttle body, headers, cam and valve spring swap. I'd also do a basic EDIS conversion with junk yard parts and run it all on a megasquirt setup. If you do a really good job you can get close to 500hp, but for a good first time out 450hp is more realistic. The EDIS, MS, and MPFI will work together to give you the ability to get very good drivability and decent MPG's too though that will be in the tuning. |
| DZ 302 Engine Build Feedback- DCR, Quench, etc. | clm69z28 | Hotrodding Basics | 13 | 12-02-2011 06:29 AM |
| ford 302 engine build | rangerkid | Engine | 2 | 11-08-2009 01:13 AM |
| Some help with a 302 build | mr.Pinto | Engine | 8 | 07-14-2007 03:36 PM |
| 302 engine build up | My-first-rat | Engine | 0 | 05-29-2007 08:58 PM |
| want to build 302 chevy engine | Kent Wallace | Introduce Yourself | 1 | 05-08-2007 05:16 PM |
