302 engine build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2007, 08:58 PM
302 engine build up
Hello; I´m building an R block 302 engine for a customer and have a few questions to anyone there
1.The block has ARP head studs already installed and I know they use different torque than regular hex bolts.What torque?
2.The block also is 4 bolt main in the 2nd,3rd and 4th mains and I don´t know the torque for the bolts (small and big ones).
3.The engine is .020 over in the pistons and I´m installing Ross hypereutectic slugs but the machine shop left them with a little bit more clearence than the spec sheet said(.0032 instead .0027) and the rings have .020 gap first and second .022 .Do you think I will have troubler with them.I rebuild the engine because it drunk oil like ·$$%%/&()(=)¿?P¨^¨Çlll..But would I have oil consuption with this gaps?
Ahh! I forgot to mention that the engine use a vortech V-1 supercharger!
Thanks in advance for your help:Bye
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
how to build 383 chev engine 72trucks Engine 4 05-20-2007 10:24 AM
want to build 302 chevy engine Kent Wallace Introduce Yourself 1 05-08-2007 05:16 PM
New Engine build, is cam gear one tooth off? fordSR Engine 16 12-15-2003 05:05 PM
