302 engine is stalling - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2005, 01:39 PM
I have a 302 ford engine that stalls after it runs for awhile, everything looks good on the gauges but after about running for 45min. it stalls.After I let it sit for a few minutes it cranks back up and goes for a few more minutes,the motor is in a 1976 boat. The engine cranks up fine from the start, but like I said it will stall after awhile. Any help would be appreciated Thanks
Old 11-07-2005, 02:56 PM
control module??? when it dies, get something to pour over the module to cool it off. If it restarts, module..next option would be the coil getting hot & breaking down. keep a known good coil in the car & swap when this happens. After that, bow your head, & make a sacrafice to Sparrky, the great electrical god
Old 11-07-2005, 03:57 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
When the engine stalls, and will not restart, does it have spark? Fuel? What type of ignition are you running, and how is the coil mounted?
Steve
Old 11-07-2005, 04:03 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders. You will get more response to your question if you will put it in the Engine forum...also be more specific, tell what kind of ignition your are useing, tell us if you have checked anything when it does this such as is it getting fire, is it getting gas etc. Enjoy the site.
Old 11-07-2005, 04:37 PM
poncho62's Avatar
Wiki Edits: 5
moving to engine.
Old 11-08-2005, 09:01 AM
302 stalling
Thanks for the info, I'm getting fuel when I'm trying to restart but haven't checked for fire, will do that, the coil is mounted on the intake manifold and I'm sure absorbing heat from that which might be causing the coil to fail.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
302 engine swap FAIRLANE DUDE Engine 2 03-31-2004 09:59 PM
How do I prevent stalling when the engine is cold? jpd37 Engine 13 08-06-2003 09:47 PM
engine swap (302) countryboy Engine 1 03-18-2003 04:19 AM
MYSTERY ENGINE HELP!!!!!! shagginwagonvic Engine 7 06-20-2002 01:07 PM
