302 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2002, 04:43 AM
Question 302 ford
got an 84 302 h.o. originally a throttle body. I replaced t.b. and intake with an Edlebrock intake and carb. I replaced the dist. with a points dist. converted to Pertronix electronic, motor is low milage with 145 to 150 psi of compression. I drove this motor for several miles before teardown and it ran fine. now it does not fire cyls 3-4-5-7. Any thoughts?
Old 06-20-2002, 12:20 PM
FASTFORD's Avatar
Post
wow,thats a first for me.i would guess its the distributer or in that area. make sure of constant feed to dist & coil. is the pertronix unit ok? is the dist cap cracked,broken,etc? strange things do happen,how about a bad wire to the coil,solenoid,etc? you have my mind wondering now,let me know what you find,thanks. good luck. <img src="confused.gif" border="0">
[ June 20, 2002: Message edited by: FASTFORD ]</p>
Old 06-25-2002, 02:18 PM
Talking
FastFord, thanks. your post on June 6 to Shagonwagonvic solved my problem. I did not know that 302 HO's firing order is different than earlier 302's. Thanks again, Joe
Old 06-25-2002, 05:37 PM
FASTFORD's Avatar
Post
joegaddy,thats great that it was a simple fix. i just could not think of a sure fire problem but now it makes sense.thanks for the update.
fastfords 4 ever....
