302 ford, blown head gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2008, 12:00 PM
406 ss monte's Avatar
eat a beaver, save a tree
i just want a couple more opnions. i have a 302 in a 85 f150, number 1 & 2 cylinders (right bank, fist & second cylinders) only have 20-25 psi on the compression tester, a couple others had 150 psi. head gasket blown between the two cylinders leaking from one to the other?
i haven't even taken the valve cover off yet. is there any need? what would cause this?
thanks
Old 11-29-2008, 01:21 PM
DoubleVision's Avatar
I would think your guess is correct, as I have seen some Ford engines do this with low miles from the factory in the 80`s vehicles. Once you remove the head you`ll have to check the blocks squareness, if it`s over .002 it`ll have to be resurfaced.
Old 11-29-2008, 01:54 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
This wiki article may be helpful to you: Head gasket. It's compiled from 16 forum discussions and 8 articles on head gaskets.
The wiki article confirms your guess and DoubleVision's response, in the "Symptoms of a blown head gasket" section. Two adjacent cylinders with low but equal pressure indicates head gasket failure between the two cylinders.
If anyone has anything to add to the wiki article -- go for it. It's going strong, but could always use more info.
SBC 305 cracked head, blown gasket or? 35oldstruck Engine 6 11-02-2008 06:10 PM
need thin Ford 5.0 head gasket ScoTFrenzel Engine 1 06-21-2008 12:19 PM
Blown head gasket? bonzipenguins Engine 8 12-15-2006 02:02 AM
Blown Head Gasket???? hmmm Engine 4 11-10-2004 10:20 PM
Need help with head gasket on 289 with 302 heads 1967stang Engine 3 10-19-2003 07:01 PM
