Thread Tools Search this Thread share on Facebook
  #1
Old 10-30-2011, 10:07 AM
fordmandeluxe1 fordmandeluxe1 is offline
302 Ford, blue grommet module problem
I have power to both sides of the coil with a test light. New Coil, New Module, AND NEW COIL WIRE. but no spark coming from coil wire using a clamp on plug tester. Need ideas, thanks
Register now (free) or login to remove ads
Old 10-30-2011, 11:21 AM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
Last journal entry: Body mods
With a test light on the negative side of the coil, have someone crank the engine and see if the light pulses. If not you may have a bad pickup coil in the dist.
On the modules, I have never found any aftermarket ones to be of the same quality as the OEM. I used to hoard original Motorcraft blue grommet modules from junk cars. Until I discover the GM modules are easy to convert and work better. I'm running a GM module, Duraspark II dist and the coil from a 90s EFI 5.8. It's been flawless for several years.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "302 Ford, blue grommet module problem"
ThreadThread StarterForumRepliesLast Post
fuel pressure problem - holley blue pump & regstratt134Engine1805-12-2010 10:45 PM
Blue Oval Ford Nuts!!??full pull bobEngine911-11-2008 05:26 PM
Blue prints 32 ford 5 window coupefosriverBody - Exterior101-31-2006 09:14 AM
Which HEI module for my Ford probe GTpenekusuIntroduce Yourself201-24-2006 09:42 PM
ABS module problem on a 97 F150 4x4jmhollisSuspension - Brakes - Steering109-03-2005 09:53 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
