-   -   302 ford knock at idel (http://www.hotrodders.com/forum/302-ford-knock-idel-140042.html)
cliff tate 06-08-2008 10:22 AM
i have a 302 in my 32 ford, it has 289heads with 351w valves heavely ported 289conrods with trimed pistons that come to the top of the block, cam is a mild regrind old firing order. problem is at idle have a definet noise, have about10000miles on engine and noise always there. have read that high comp smal fords should use marine or wisore 351 cam (to change firing order to eliminate noise. any one out there with a opinion or experience . thanks cliff
carsavvycook 06-08-2008 10:36 AM
I was told about this years ago, and I can say that a customer of mine, with a HP289 in a 1965 Mustang, uses the 351W firing order.
