302 ford knock at idel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 10:22 AM
i have a 302 in my 32 ford, it has 289heads with 351w valves heavely ported 289conrods with trimed pistons that come to the top of the block, cam is a mild regrind old firing order. problem is at idle have a definet noise, have about10000miles on engine and noise always there. have read that high comp smal fords should use marine or wisore 351 cam (to change firing order to eliminate noise. any one out there with a opinion or experience . thanks cliff
Old 06-08-2008, 10:36 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I was told about this years ago, and I can say that a customer of mine, with a HP289 in a 1965 Mustang, uses the 351W firing order.
Which heads should I use on 302 Ford? Coleman396 Engine 8 11-08-2008 02:29 PM
302 ford transfer tube between heads 39 chev Engine 4 10-30-2005 11:27 AM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-07-2005 12:01 AM
302 Ford Small Block Identification Drean Engine 6 08-08-2005 02:19 AM
Ford 302 into a 1940 Ford questions. cyberbear Engine 2 07-20-2004 09:29 PM
