302/Gas Mileage - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2004, 08:11 PM
1980 Malibu's Avatar
302/Gas Mileage
What are some ways to improve gas mileage.....I fill my tank up yesturday and i drove about 54 miles all together and im at like a half of a tank, its a 15 gallon tank, my gas mileage is horrible, how do i improve it??? ITs also Fuel Injected 302 in a 1987 Ford F-150
Old 07-02-2004, 08:27 PM
DoubleVision's Avatar
K&N air filter, low restriction exhaust system, tune it up with the best parts you can afford and use spiral core plug wires and route them correctly. Fill the rear diff with Royal Purple gear lube, this cuts rolling resistance, check the front wheel bearings and repack if needed, check the air pressure in the tires, leave the tail gate down, and most importantly, drive it as if there`s a egg under the accelerator pedal.
Old 07-02-2004, 10:22 PM
docvette's Avatar
Wiki Edits: 12
Re: 302/Gas Mileage
[color=lightblue]Doc here:
That's like 7.2 miles per gallon, Provided your Fuel gauge isn't scamming you.
See what Chips are Availble to you for econmy and replace it. Run some Good injector Cleaner through it...and Do All, As Double Vision Suggested.
While 7.2 MPG is not all that Great.. Still It is a 1/2,? 3/4? ton Truck...
Don't haul tools, truck boxes or anything you Don't really have to haul to lighten the load...yur Road Dawgie's Fat Auntie...
Other than that...
Public Transportation??
until, At least , if ever, the fuel prices drop a bit...
Personally, I'd Kill for 13 mpg on my Car... but that's another story...
Doc
[/color]
Old 07-03-2004, 07:55 AM
its 1/2 ton truck
Old 07-03-2004, 08:57 AM
Never check your milage by the gas gauge. You must start with a full tank and then find how much gas it takes to fill it to be even close. Does your truck have oversized tires? If so you'll need to correct the odometer or figure te difference into your milage. With my truck just changing tire size thrown the odometer off about 12%. Was that hiway or city miles? Also 54 is an awfully short distance for checking your milage. Check it over a full tank of gas if your staying in town.
Old 07-03-2004, 10:23 AM
its got 31's on it, and i think my MPH gauge is WAYYY off lol. it says im doin like 60 but i think im doin like 80
Old 07-07-2004, 01:52 AM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
yeah thats right, dont use your gas gauge... fill up your tank and take note of your milage, then drive tell the tank is almost empty, then when you fill up wright down your milage again and how much fuel you just put in the tank and do it that way...
Old 07-17-2004, 07:58 AM
Tazz
stock setup is best
You will need to go back to the stock tire size and then add the K&N filter and the other suggestions to get the BEST gas milage in your PU truck.
Tazz
Rat Rods Rule!
