302 head gasket installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2009, 05:40 PM
cboy's Avatar
Last journal entry: Finished
Just double checking that I'm doing this right. The 302 Ford block has water jacket holes in the front of the block (and head) but the head gasket does not have corresponding holes. (see pictures below). Is that the correct installation...to block off the front water jacket passages to the head? My understanding is this forces the water to the rear of the block where it enters the head.
Always learning...and sharing what I've learned.
Old 07-08-2009, 05:45 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Yes it does block off the front water ports. This is to force the coolant to the rear, to aid in not overheating the block, and heads.
I can't count how many I have torn apart a DIY had put together.
Old 07-08-2009, 07:21 PM
Confirming CARSAVVYCOOK as this is big time important. Coolant moves thru the cylinder block, comes up the rear to enter the head, moves forward thru the head to return. Reversing the gasket would allow cold coolant entering from the pump to have a direct path back to the radiator without bothering to cool anything beyond cylinders 1 and 5 on a Ford or 1 and 2 on a Chevy. This means that one head gasket will set upside down.
Bogie
Old 07-08-2009, 09:09 PM
cboy's Avatar
Yes, that got me a little confused as well. On one bank the gasket goes on with the textured surface and blue markings (as shown in the picture) up and on the other bank the blue markings are down and the coated gray surface is on the up side. Strange.
Anyway, thanks for the confirmation on this guys.
3830711 GM Head Gasket installation... talisman51 Engine 0 04-11-2007 07:06 PM
Head Gasket or Piston Rings? 94dangerranger Engine 7 03-24-2007 02:33 PM
sbc 350 Head Gasket question oregon chevelle Engine 1 04-24-2006 02:25 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 11:08 PM
Felpro head gasket specs 8843astro Engine 0 05-19-2004 02:21 PM
