302 head porting
how much hump can you safely in the exhast on 78 302 heads ?
It looks like you want to "build on a budget" the '78 302 heads are not really a good choice but this will give you the info to start with:Porting Stock Cylinder Heads - Ford E7TE Heads | FordMuscle.com best bet would be something like these:1966 66 FORD 289 CYLINDER HEADS PAIR 1965-66 289 heads have a smaller combustion chamber for more compression,they use adjustable rocker arms and there are no humps this will give you some extra info:Ford Small Block Cylinder Heads, Valves and Valvetrain read the section on 289 heads which are very similar to the 289 HI-PO's,you should buy this book to educate yourself further.
casting quality
You can feel inside the ports and sometimes casting core mold mis- match will leave a ridge you can feel. Just removing those and smoothing the runners can make a difference. also a lot the old Ford carbs had a mold misalignment, the carb bores can be carefully cleaned up.
| head porting | crowerjunky | Engine | 11 | 05-18-2011 08:36 PM |
| Head Porting | 428BIRD | Engine | 12 | 02-01-2010 04:29 PM |
| head porting ? | machinestheman | Engine | 4 | 12-18-2005 10:35 PM |
| head porting | mitmaks | Engine | 4 | 11-01-2005 12:04 AM |
| Porting/Polishing 1978 302 Heads | CREVISTON | Engine | 6 | 09-13-2003 05:12 PM |
