302 HO information - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2013, 10:23 AM
302 HO information
My 302 has xxx In valley ! but how can i tell If it is a HO motor?
Thanks AL
Old 06-26-2013, 10:58 AM
Wiki Edits: 27
ho firing order
The HO engines should have the Marine cam shaft and use the 351 Firing order, have a double roller timing chain set. the 4 barrel Holly's were modified to be able to run thru the entire govt smog test on only the front 2 barrels. carb rework can help somewhere I have the Holly Mods recomended by a Ford Engineer.
Old 06-26-2013, 11:10 AM
302 ho
How can i tell If my 302 is just A 302 motor
Or a 302 HO motor ? It has a xxx in the valley Code
# is E8SE OR E6SE . Thanks AL
Old 06-26-2013, 11:23 AM
302 HO motor
My 302 is just a long block not sure about the cam?
It does not hahe rolers. just XXX in the yalley E6 OR E8 SE
Ido not have fireing order? AL
Old 06-26-2013, 01:01 PM
Banned
is it a chevy 302 or a ford 302?
Old 06-26-2013, 01:05 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Welcome to the board
Moved your post to a tech help forum, site help is for hotrodder/internet site problems.
Semper Fi
Old 06-26-2013, 01:16 PM
Banned
xxx in the galley means it is roller cam motor if it is a ford 302
Old 06-26-2013, 02:30 PM
302 ho
Ford 302 gust trying to find out if its a HO or just A 302?
I want to set the valves an find out the fireing order.
THANKS AL
Old 06-26-2013, 02:56 PM
Banned
XXX is a ho motor that is why it a roller motor
Old 06-26-2013, 06:28 PM
Wiki Edits: 27
s bird ?
The s used to mean the part was originally designed as a thunderbird part. But that was years ago. I don't know if that applied to block castings............ read up here,,,,,,,,http://www.mustangtek.com/FordDecode.html
Ford 302 Merc Cruiser 302 Way 2 Many Projects Engine 9 10-26-2011 10:40 PM
Chevy 302 Information Needed MississippiMuscle Engine 17 11-21-2006 03:17 PM
can i destroke a 351 w with a 302 or stroke a 302 with a 351w? jims84gt350 Engine 5 04-02-2006 01:04 PM
Information on 400 HP 302 99ragtop Engine 3 12-19-2005 11:47 AM
change a 302 into a boss 302 amc Engine 3 08-25-2003 05:51 PM
