302 ho will not idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2012, 11:57 PM
hopfully somebody can help me i have 1991 302 ho in my 1969 galaxie fastback it was running great with a 2b carb upgraded to a procomp street strip intake and distr,a edelbrock 1406 and a set of edelbrock timing gears and high flow fuel pump and now the car will not run under 3000 rpms I have gone over everything and it all seems to be were it needs to be.and i have even put the old timing chain and fuel pump back on and is the same can somebody please help
Old 08-28-2012, 03:31 AM
JeffB's Avatar
The Edelbrock 1406 does not like fuel pressure above 5.5 psi you should have a pressure regulator on it.Even your stock fuel pump may be above that so try to regulate it at 4.5 to 5.0 psi. Your Pro-Comp distributor probably has a 24 degree mechanical advance curve,set it 10-12 degree advanced with your timing light,works on my similar setup.
Old 08-28-2012, 06:13 AM
Irelands child's Avatar
To add to what Jeff said - a large vacuum leak can also cause that problem as well. You need to get the rpm up to create enough air velocity through the carb to pull fuel 'through' to engines comb. system instead of relying on atmospheric pressure to push it.
Irelands child
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 16 03-23-2012 06:29 PM
SBF 302 Rough idle/pedal=Battery low charge??? fittyfod Engine 3 04-03-2011 10:07 PM
Rough Idle, No Power SBF 302` fittyfod Engine 8 01-12-2011 10:36 AM
BG/BC Rich Idle & Idle Air Bleeds/IFR 68NovaSS Engine 3 11-11-2006 12:36 AM
92 ford 302 EFI wont idle cgreene General Rodding Tech 5 11-05-2003 09:50 PM
