302 leaks water, drips off back of the engine - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-17-2011, 11:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 39 OLDROD
You mite check the thermostat housing as they are bad to leak if you use the old one . I had A PITA with mine until I got a new one and yes the water WILL run every where. just a thought. good luck
OLDROD
Good point. With the engine running, the fan can push a leak further rearward than where it originates from. And after a drive, coolant can collect in other places than the leak, too. Then when you park the dripping won't necessarily show you the exact location of the leak.
That said, you should at least try to use the drip locations as a hint when you first go a'lookin'. And no need to take the 'easy' way out by using some sort of dye or whatever.
I agree getting under it (w/the engine running if need be- like if you cannot locate an obvious location of the leak w/the engine off) is the surest way to tell. Using a hydraulic lift would be ideal. You'll need a good light, and whatever you do, DO NOT get under it unless it's supported redundantly. Ramps alone are not enough. A floor jack alone or jack stands alone aren't enough either- you need two or more means of support, one backing up the other.
I could go on, but you surely get the idea- safety first. People die every day from crush injuries.
  #32 (permalink)
Old 05-18-2011, 06:11 PM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
that is true the oldrod said, had that happen b4 on my dad. the chevy we did engine swap on did that, it was tbi aluiminuim, we some how screwed up the thermostat housing or someone before us did. Wasnt very fun tryin to re-tap the bolt hole out for a bigger bolt thats for sure. Im gonna check this all out, we might also check the acidic stuff in the radiator. You guys are a bunch of help you guys knowledge is greatly appreciated! Like im just starting hotrodding and im waiting patiently for hotrod project number one to come to clutchs of my hands and when it does i hope ya'l can help me!! Friend's, Alex
1940 Plymouth leaks water AUTO NUT Engine 5 08-05-2010 06:36 AM
Water leaks inside my interior? Madmax305 Body - Exterior 11 03-29-2010 08:33 AM
No drips, No runs, MAJOR Error Frisco Body - Exterior 6 03-09-2007 08:14 PM
Water leaks from i dont know where? Meangreen Interior 9 07-22-2003 03:17 PM
Water in the engine!!! HELP!! jazzguitar Engine 3 11-05-2002 08:58 PM
