302 oil pan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2012, 03:35 PM
Hello Ford People!!!
My father-in-law has a 57 Fairlane he is building. Frame is stock. He is using a rack of a 72 pinto. The engine is out of a 91 F150 302 non-4x4. Since the truck was originally a rear-sump oil pan, we cannot use it due to the fact that the rack we installed will interfere with the rear sump pan. The help I need is where/how do I locate a front sump pan that will bolt up to it? Thank you!
Old 05-13-2012, 03:52 PM
fromt sump
most older 289 and 302 cars had front sump,go to a wrecker get the pan and oil pump pickup and you ar ther
Old 05-13-2012, 07:32 PM
Wiki Edits: 27
dip sticks
Ford moved the dipsticks around quite a few times. some in front cover. some on side of pan Etc one more thing to check.
Old 05-14-2012, 02:29 AM
JeffB's Avatar
Here is a source for front sump pans http://www.kmjent.com/cart/home.php?cat=20164538 they also have the matching front dipstick.You will need the matching pickup also, Melling part#68-S about $10 at your local Autozone.You can drill your existing timing cover for the front dipstick if you plan on keeping the F-150's fuel injection,do it with the pan off and place rags around the crank so any filings will fall to the ground then plug the side dipstick hole.If you are converting to a carburetor then you might want to change to an earlier timing cover that has the provision for a manual fuel pump and the dipstick hole is predrilled.Your rear sump pan and pickup is needed when swapping into a 1949-53 Ford car so it is a sellable item.
400 SBC oil pan question..What quart size of pan do I need? heathj1 Engine 10 07-26-2010 09:26 PM
Ford 302 rear sump oil pan Lippy Engine 1 03-07-2010 11:15 AM
Oil pan question cdiedrick Engine 3 10-16-2007 08:57 PM
Oil pan Question mrbob Engine 4 03-07-2007 11:04 PM
Oil Pan Question - Ford 302 30Coupe30 Engine 1 06-18-2006 03:31 PM
