Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 302 is out. What next?
Old 12-30-2012, 07:33 PM
Torque454 Torque454 is offline
id replace the timing chain atleast. On my 302 I'm planning to replace the bearings and oil pump in mine (althought it knocks on startup) and the timing chain as well as a cam (since I tow, figured a marine or RV cam would be good to do while its out and apart) and headers and all new gaskets and seals, including valve seals. I dont plan to pull the heads or do anything to the bores/pistons/rings, but that may change after I do a compression test.
