Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 302 roller buildup suggestions?
Old 03-02-2004, 09:51 PM
billybob_v10's Avatar
billybob_v10 billybob_v10 is offline
I just aquired a 1988 302 HO long block from an 88 mustang for $50. I am boring .030 over and would like to put on the Holley SyteMAX II Kit from summit. The kit inludes new Holley heads, new intake, timing and cam. The ad states that with the kit, the 302 will push about 350hp. Can I use that kit in conjunction with the 347 stroker kit? Will I need to change cams because of the stroker kit? How much hp will the two push together if they work? Will the new intake from the Holley kit flow the proper amount of air required? Thanks for your help. Billybob
Or would it be better to just rebuild it with the Holley kit and not do the stroker? If I use the two in conjuction, what intake will perform the best and flow the amount of air needed to fuel the beast? Thank you, billybob
