302 set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 06:13 PM
302 set up
I have a classic race boat i am restoring and would like some help setting up the engine. This boat has been apart for 15 years and i would like it to be reliable but fast if asked. The motor is a 302 winsor with 351 2v cleveland heads it uses a special intake manifold and some work to the heads to adapt.The cam is roller and a 600 holley. It also has a wet nitrous system.My question is it has a stock vac advance distributor with points. will this be ok for what i want or should i change to elect distributor and what kind.Also do i any thing if i run the nitrous, i saw something that retards the timimng when you hit the nitrous thank you
Old 03-18-2009, 07:12 PM
nitro_baller4692's Avatar
floppers forever
http://www.msdignition.com/info.aspx?taxid=38
How to get a Chevy 302 under 10:1 CR VetteInOz Engine 21 09-08-2010 09:53 PM
302 chevy engine mess NaythanOldskool Engine 17 12-18-2008 12:04 AM
Dz 302 question. NaythanOldskool Hotrodding Basics 3 12-13-2008 09:25 AM
timing chain set questions Boosted89RS Engine 7 04-09-2008 11:59 AM
302 question 49fordp/u Engine 1 12-02-2007 05:25 PM
