302 Swap in 69 Mustang
I have a ’69 Mustang with an anemic 302 in it… what’s the best (largest) engine that will bolt up to a c-4 auto tranny? I’ve always been a GM guy… sorry for the stupid question.
1 Attachment(s)
vf,
a 460 bolts up to a C4....but...ya gotta beef up the C4 to live with all that torque..... pretty easy to build a 460 to 500ft/lbs+ 68' thru 70' (all the same unibody) Ford stuffed just about every different big block they made at that time into Mustangs.... here's what a SCJ 428 would look like in your bay (customer's car at the shop for restoration) |
Ha, you read my mind... a 460 is what I had in mind... what do ya gotta do to the tranny?? Is there a kit or something??
You can buy one already set up to handle a lot of power or I guess a transmission shop could do the same thing. A 460 has a lot of power but will fit tight in your bay. The Mustang won't handle as well with all of that weight on the front end. A 351 Windsor can be stroked out for a lot of cubic inches and with all of the aftermarket parts it can be made into a great performer. It is also a lot lighter than the 460. Another route would be to stroke your 302 to a 347. They can also be built to have amazing power.
Danny |
Thanks a lot... maybe I'll go the 351 route. Thanks again!!
vf,
you asked for "biggest". I answered 460.... but what is the hp/tq/et/etc goal your looking for.... "if" you just want to go really quick once and awhile....a $500 nos kit would do it on your 302 |
I've heard nos will damage you engine. Any thoughts?
vf,
any/all of the NOS suppliers/mfgrs web sites have a "info" page like this link example: http://www.forcefedperformance.com/Services_NOS.asp look up all the different kits mfgrs on summit or jegs....each site will have more or different additional info |
As always, THANKS for the info!!
vr,
your welcome but to be honest....it would take me forever to type all that out with just 2 fingers! food for thought: Key to any fun street car is max TQ (not hp) to the tires at all normal driving rpms... TQ=real "force"=push you back in the seat fun very very generally cubes=max TQ (why a 460 will give you a neck ache) stock 302 with a decent tune up is 300ft/lbs 300ft/lbs x 3.00 gears = 900 ft/lbs of twist force on the tires 300ft/lbs x 3.73 gears = 1,119 ft/lbs of force on the tires=Hg is higher=more TQ with less load and a pretty darn good increase for "wow" acceleration with very little gas pedal $500 gear swap is the best bang for the buck on a 302...ain't got cubes change gears for the same tq at the tires... stock 351W motor x 3.00=1050 ft/lbs at the tires approx TQ cam on a 302=about 320ft/lbs 320x3.73=1193 |
While a 460 will go, it will require apron work. The car will then be nose heavy and only fit for straight road driving (hot street). (IMO) A lightly modified 302/351W will give you much more roadability unless you are just looking for flat out performance. |
you also ask wkat would bolt to the bell housing. that would be 302/351. to bolt up a 429/460, you have to change bell housings. they are avail, but pricey. best bet 351 windsor.
guys,
I went back and changed my post to: just say: Ford "big block motors" (not 429)....cause about every motor Ford built was stuffed in them.... vf, food for thought: I'm not a big fan for starting with a 351W....250hp/340tq stock.... because it has the (small valves, TQ biased I/E) 302 heads on it.... to get performance above about 4500rpms.... you have to buy after market heads..... "but" the brand new totally complete (intake/dist/etc) crate motor is a heck of a buy ($2800?) and is definitely a fun "cruiser" motor just stock.... it is taller than a 302 in a Mustang so do check the air filter and carb and intake hood clearance before you buy I do agree with putting in a big block does ruin the handling.... |
whoops, double post....(server hiccup?)
| All times are GMT -6. The time now is 07:05 PM. |
