one tooth off
check and see that you are not 1 tooth off retarded or advanced, fords like a straight up cam timming
When you mentioned firing order being correct and you stated that you are using the E303 cam remember Ford changed the firing order in 1985 when they went to roller cams,if you used the earlier 302 firing order it will do what you are describing.Also check the float level on your Holley.
The firing order is correct, and the issue began when I replaced the distributor, So that should eliminate carb problems. How would I tell being a tooth off? Theoretically, I could make any terminal #1 on a new install, right? And there is adjustment room on the housing, so would think I might be able to adjust out a minor bit.
I'm just thinking out loud here. Feel free to correct my logic. Thank you gentlemen for the quick response........ |
roller cam fireing order
Frustrated
Well, I've rechecked everything and replaced everything but the carb, MSD box and right door handle. Checked for vacuum leaks. Electrical gremlins. Nothing. And yet it will be simple when I find out what it is.
Any help will be appreciated. |
This problem is mysterious. Just brainstorming; Are you certain you were at TDC before determining that you were 10 degrees BTDC. Just asking, but it seems if it was close enough to run at all you could dial it in. You didn't by chance change the timing set and misaligned the cam to the crank did you? If not it makes the distributor itself suspect maybe?
I've checked the timing tons of time in the last week. It was @ TDC. I pulled the timing cover again and checked it. Not out of timing. Think I'll check the compression. Wondering if its an exhaust valve, because at idle you might not know it with the cam lope. I'm thinking maybe the Lord is keeping me humble...
Ford 'E 303' roller cams have the 351W/HO firing order. There is no doubt about that. There could be doubt about push rod length though if the engine was originally a flat tappet. There is also doubt if the timing is 180+/- or some other number of teeth out as it WILL backfire in the exhaust and through the carb, barely run, if at all.
It that harmonic balancer is a replacement, many have 2,3 or more sets of timing marks, depending on the timing housing and pointer. That distributor cap may be cracked, allowing cross fire, even a new one, the rotor may have a loose outer electrode, missing or with the current QC in many of the Chinese suppliers building parts, totally indexed wrong. The spark plug wires may be cross firing as well. With an MSD box, you DO NEED spiral type wires or they will have an inductive cross fire. An MSD box and coil will 'throw' a 2" spark with ease, so all that plug wiring needs to better then good. It will set you on your butt if you happen to grab the distributor top to set the timing. ![]() The 5.0 engine above, full MSD, E303 cam, 1.7 roller rockers runs like a dream and for quite a few miles |
But the baffling thing is, if the mixture is igniting in the exhaust, then the cylinder(s) are NOT firing at rpm. Note: even though this is a 5.0 and uses that firing order, I am using a vacuum advance distributor, intake and carb off an '82 302, Its been working for over a year now. Did away with all the EFI stuff. Gonna pull the valve covers and distributor cap and walk through the firing order today. Perhaps I'll find something there.... I do know all the cylinders are firing though, at least with the remote starter...
Solved
I knew it would be simple once I hit on it. The new distributor had different color wires. Guessing, i had it right, but had changed the firing order to 302. I changed the wiring AND the firing order at the same time. Lesson learned. Change ONE variable at a time.
So for all you 5.0 guys using an MSD 6AL, the black/red wire goes to the purple and the black/purple wire goes to the green on the MSD harness. Thank you all for your time and help. |
289 1-5-4-2-6-3-7-8 302 (Pre-82) 1-5-4-2-6-3-7-8 5.0 1-5-4-2-6-3-7-8 5.0 HO 1-3-7-2-6-5-4-8 5.0 Truck 1-5-4-2-6-3-7-8 351 1-3-7-2-6-5-4-8 1 thru 4 is on the pass side, 5 thru 8 on drivers side. The distributor rotates CCW as you look down on it |
| 305 Timing problem | mtncat | Engine | 3 | 03-15-2006 09:30 PM |
| Timing problem | 85IROC | Engine | 8 | 03-15-2006 09:24 PM |
| timing problem | steve05 | Engine | 2 | 10-19-2005 06:51 PM |
| starter problem ? timing problem? | 6speedwagon | Engine | 1 | 08-11-2004 11:37 AM |
| Timing Problem | 71gtx | Engine | 4 | 11-10-2003 03:58 AM |
