302 valve issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 06:14 AM
302 valve issues
Hello peoples,
I have a 1975 Ford F100 w/302 (not sure if its original or not) when i got the truck it had some issues like the timing 180 out, little things like that. My question and problem is that no matter what i do i have a valve that does not close properly, at idle it has a sound (close to a water pump bearing going bad, or a leaking header) but if you get on it a little, it goes away, as soon as you let off, it comes back. I have adjusted the rockers, and installed a new gasket on the header, and still no change. does anyone have any suggestions?
Old 04-24-2012, 07:04 AM
BOBCRMAN@aol.com's Avatar
Take a basic compression test. Results will dictate your course of action. Stuck valve is usually carboned up from bad guide/seat or bent.
Old 04-24-2012, 07:22 AM
Why is it the simplest things we forget to try with age. Lol thank you.
Strange oil pressure issues with ford 302 Torque454 Engine 12 05-11-2014 02:55 PM
51 Ford F-1 W/302 Radiator Issues 65bluess Engine 2 12-12-2009 06:28 PM
51 F-1 W/302 Auto Radiator Issues 65bluess General Rodding Tech 3 11-18-2009 03:31 PM
valve issues? jrm123180 Engine 5 08-01-2007 09:42 PM
Valve train issues. meschnebly Engine 6 10-25-2006 12:21 PM
