302 vs 289 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2002, 11:48 PM
kidvid's Avatar
Have Mustang Will Travel
Question 302 vs 289
My machinist ruined my 68 Ford 302 block while boring it. He admited his mistake and said he would replace the block. He called today and told me he could only get a 289 block that would bore out to .40" over and that the two blocks are exactly the same.
The problem is my rebuild kit is a stroker setup for a 302. Plus my heads and new cam are 302.
I understand that the 302 has a little more cylinder at the bottom of the bore to make it more stable when they went to a 3" stroke. And that there could be a difference in the bellhousing and pushrods.
What problems would I encounter going with the 289?
Should I accept his offer or make him replace the 302?
Old 10-17-2002, 03:11 AM
woodz428's Avatar
Troll Hunter
Post
I'd hold out for a 302. 289 blocks are more scarce than 302s(they haven't been made since 1968).After 1965 the bellhousing isn't a problem and the pushrod difference has to do with head variations.But the cylinder difference is why I'd hold for a 302, he botched a 302 and should replace it with the same.
[ October 17, 2002: Message edited by: woodz428 ]</p>
Old 10-17-2002, 05:55 AM
New Member
Post
The difference isn't much in the cylinder wall,but, Ford didn't extend it for no reason at all. With a stroker I would definitely hold out for the 302 block as was recommended. Later, Jay
Old 10-18-2002, 09:34 AM
New Member
Post
You’re right about the cylinder wall being deeper on the 302, but that isn’t the problem. When you stroke an early (don’t remember the year off hand) 289 block, a couple of the rods will contact the bottom of the cylinder wall sleeves. You or your machinist need to check this during assembly. I used an air grinder to remove about ˝ an inch of material from the walls. No big deal, but why go through the hassle ( I only did it because I waned to retain my 4 bolt main HP block.) - 302 blocks are as common as dirt. As I remember, there are 5 and 6 bolt bellhousings for the 289 – just count ‘em.
Doug
Old 12-10-2005, 10:42 AM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
He is right there are five and six bolt patterns for 289's. This is something you need to be very careful of.
Old 12-11-2005, 12:54 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Doug
1) I have set several 289 and 302 blocks side by side and measured the cylinder length.
the difference in cylinder length is irrelavent because the factory puts a chamfer on the lower end that varies as much as .070 in depth from block to block. A deeply chamfered 302 block is as short as a 289 block. Boring the cylinders reduces the chamfer. .060 over usually eliminates it completely.
2) 347 strokers are running in 289 5 and 6 bolt blocks without problems. 331 would be better (actually I prefer 331 over 347 anyway)
3) Shorter cylinders will require LESS grinding for stroker clearance.
4) There were NO assembly line 4 bolt main 289 or 302 blocks. HIPO blocks had heavier cast main caps. Even light cast 5.0 blocks take 500 hp before blowing the bottom end out.
5) 1968 (only) 289/302 blocks were identical castings.
Old 12-11-2005, 04:43 PM
Max Keith's Avatar
289 vs 302 blocks
The only differences Im aware of in production 289 and 302 blocks is the bellhousing bolt pattern of the 66 and earlier 289. If the block hes offering is a 68, 289 block, and you arent concerned about going more than .040" over on the bore, I suppose its an ok deal, since the only difference in a 68, 289 and a 68, 302 was the displacement.
If you are planning to put a stroker crank in it, you are going to have to have the bottoms of the cylinders cut for clearance for the rods, whether its a 289 or a 302.
Hmmmmmmm, I wonder if your machinist ever heard of sleeving a cylinder and reboring it?
On boring out an SBF, Ford only recommends going .030" on any of them, so it would need to be sonic tested if you are interested in going more than .030" over on the bore.
Old 12-11-2005, 10:42 PM
xntrik's Avatar
There are gazillions of 289/302s that have been bored .060 with no problems whatsoever...
If it were a 5.0...... I think that I would not go that big.
www.readershotrods.com drag cars/ georges drag strip
Name:	George ray 21 Aug 2005 013.jpg
ID:	8281   Click image for larger version
Name:	George ray 21 Aug 2005 028.jpg
Old 12-13-2005, 05:40 AM
mstngjoe's Avatar
Originally Posted by xntrik
4) There were NO assembly line 4 bolt main 289 or 302 blocks......
The Boss 302 block was a 4-bolt main.
Old 12-13-2005, 08:45 AM
Rev It Loud, Drive It Proud!
The tunnel port 302...
I would wait for the 302 block. He should replace what he destroyed.
Old 12-13-2005, 09:25 AM
kidvid,
trying to say this nicely?
I suggest you re-think your build because:
your wasting alot of HP/TQ and/or (stroker) $$$$ using 302 heads (1.78/1.45 valves) and a 302 cam on a 347 stroker (good for a rock crawler Jeep?)
agree with Max and xntrik, the skirt length is a "non issue"
Old 12-13-2005, 12:13 PM
xntrik's Avatar
Oh ya, Ford put one of those in my 69 Galaxie station wagon.... come to think of it, it WAS a dual quad tunnel port too.....
Old 12-13-2005, 01:07 PM
brainsboy's Avatar
brains
Yeah but your never going to find a BOSS block and if you do usually people think they have something worth more then gold.
As long as were on the subject dont forget about the 302 Mexican block, which still can be found and personally I feel they are just as strong. It's almost the same casting as the BOSS block with the thicker and stronger mains and deck. The Mexican blocks only difference is that it is a 2 bolt main.
Old 12-14-2005, 10:20 AM
xntrik's Avatar
I have a difficult time considering the BOSS 302 (and even BOSS 429), 302 tunnel port as regular "assembly line" engines...
Yes they were installed but they can hardly be considered a regular production option.
And yes, the actual cylinder metal hanging down is slightly longer on the 302 than the 289 but in practicality it is irrelavent. There ARE quite a few 5 and 6 bolt long strokers running with no ill effects noted.
Old 12-14-2005, 01:39 PM
mstngjoe's Avatar
I have a difficult time considering the BOSS 302 ......as regular "assembly line" engines...
There were over 9000 Boss 302 engines installed in Mustangs and Cougar Eliminators that went out the door in 1969 & 1970.
I don't know what number it would take for you to consider the Boss 302 an "assembly line" engine, but most Ford people think of the 4-bolt Boss block as qualifying.
I would agree that the Boss 429 and Tunnel Port are a different story though.
