302 vs 302? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 05:38 AM
TroyBoy's Avatar
Psychomotors
302 vs 302?
Okay,all I hear is how a 302 Chevy is no good,blah,blah,blah.I'm a Chevy guy so...I have a 97 Mercury Mountaineer with a 302 thats will flat out haul a**. How come they have the same bore and stroke but everyone hates the Chevy and praises the Ford????It's something that has nagged me for years.
Old 09-07-2010, 06:34 AM
Its the 307 and the 305 Chevy that dont make very good performance engines. The Chevy 302 was only offered in the 67-69 Z-28's and was designed for Trans-Am(road) racing. Advertised HP was 290, but it made well over that, and was a race winner right from the start. Gears, Headers, the factory Cross-ram intake all made this motor a real screamer.
But the only reason now-a-days to run a Chevy 302 would be because of rules restrictions on Cubic inches. If rules dont require a specific cubic inch, you should run the largest cubic inch motor you can afford.
Old 09-07-2010, 06:48 AM
I'm not sure who you've talked to but most people will take the chevy over the ford... Chevy 302s aren't often done because a 350 is easier to come by and bigger, 302 Fords are done a lot because they are easier to find engines and parts for than 351s.
Old 09-07-2010, 06:58 AM
poncho62's Avatar
Wiki Edits: 5
Applea and oranges......The 302 Chevy was a special built engine basically for trans am racing........they had to build a street version to be legal.....
the 302 Ford was a mass production engine, built for years in pretty much everything Ford produced.......
The Chevy 302 would way out perform a stock Ford 302.....
Now, if you really wanted to compare, you would have to compare the Chevy 302 to the Ford Boss 302.........both low production, hi perf engines.............
Old 09-07-2010, 07:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Ford 302 uses a 5.09" con rod. Still has a 1.7 rod/stroke ratio. The SBC 302 sports a 1.9 ratio- some would say that's too much, the "ideal" HP ratio being ~1.8.
So I guess the 302 SBC rod needs to be 5.4"- the same as a lot of Ford 302 aftermarket rotators use. Or not.
No one I know bad mouths the SBC 302. Actually, it's an icon. The little Ford 5.0L is also a good engine, it was used so extensively that they're easily found for cheap and can be made to run real good- as a 302 OR a 347.
The short 8.206" deck height of the 289/302 is a selling point in some applications- it will fit into engine bays like the MG, AC Ace, etc..
Old 09-07-2010, 08:19 AM
TroyBoy's Avatar
Psychomotors
Actually what I was getting at is I wonder why Gm didn't de-tune it and use it as their economy engine.I still think the 307 with the right parts was a good engine also.Its just that everytime someone on here starts talking about building a Chevy 302 they are bashed.I don't know what they want from the engine,but if you wanted to build one for economy with FI it would'nt be too bad.My Mercury doesn't RPM worth a crap as far as a high RPM engine is supposed to do but it does take off well with its 3.73 gears and gets decent MPG with the OD. I'm not looking to build anything, just wanted some honest debate.
Old 09-07-2010, 08:27 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Part of the reason they didn't de-tune it for economy was market perception. No one would respect the 302 like they do if it spent three years as a super hi-po engine, then spent 20 years as a wheezy smogger.
Its like when they tried to make a high-performance version of the 305. Sure, it made 50 more HP, but its only 190 hp total.
The 302 would make a fine economy engine properly tuned, but so does a 350 and it provides gobs more torque in the process.
Old 09-07-2010, 08:33 AM
TroyBoy's Avatar
Psychomotors
I understand your point and well said.
Old 09-07-2010, 08:34 AM
lg1969's Avatar
Google "Tunnel Ram 406"
First you are comparing a stock ford 302 that made for the streets and that is torque. A boss 302 that was built the same year as the Chevy 302 had the same problem. They both ran 11:1 compression, both had big cams, both used big Holley carbs, and the boss 302 had big valve heads with the use of the tunnel port intake. The intake port flowed more air then the big blocks. They both had one Major issues, they both suffered low end torque. The standard ford 302 does not have these issues. The low end torque on a ford boss 302 was much worst because of the oversize intake ports. Chevy 302 is strickly a race motor. The boss 302 and the Z/28 302 could rev to the Moon.
Old 09-07-2010, 09:48 AM
TroyBoy's Avatar
Psychomotors
So what you are saying is that a Chevy 302 with a set of Vortec heads and complimentary cam would be a good combo?
Old 09-07-2010, 09:54 AM
lg1969's Avatar
It will work fine. Just watch with the compression.
Old 09-07-2010, 09:56 AM
TroyBoy's Avatar
Psychomotors
I agree
Old 09-07-2010, 10:43 AM
The easiest way to get decent compression with that combo is to either get the pistons with the correct Vortec dome, OR use 305 Vortec heads. The 305 heads with a good valve job and some light port clean up can slow enough to support 400hp, and the smaller runners (than the 350 Vortec heads) should help low end slightly.
Old 09-07-2010, 11:37 AM
lg1969's Avatar
If Chevy build a street version like the ford 302. It would have similar horse power and torque as the standard ford 302. A 600cfm Holley and a smaller cam would perform better then the 780cfm Holley that was used on a chevy 302.
Old 09-07-2010, 12:12 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
I think the Ford 302 factory crank is 15 or 20 pounds lighter, like 36 pounds? anyone know?
1967 mustang 302 conversion questions jcoby Engine 9 04-04-2009 06:22 PM
302 chevy engine mess NaythanOldskool Engine 17 12-18-2008 12:04 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
can i destroke a 351 w with a 302 or stroke a 302 with a 351w? jims84gt350 Engine 5 04-02-2006 01:04 PM
Chevy 302 purplenova Engine 6 10-25-2002 07:26 PM
