304 slow to start after warm - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 05:04 PM
Hi again, I have amc 304 and it starts right up when cold and barely cranks when hot. I've moved the dist and it doesn't make a difference. Any ideas ?
Old 04-03-2010, 07:48 PM
sqzbox's Avatar
My pipes are my music
Sounds like the starter is just getting old being it's hot when it won't crank.
Check the cable connection at the starter and make sure it's tight. Be sure to disconnect the pos cable at the battery first.
Be sure to check the battery condition and alternator output. Slow cranking is also a sign of an alt. on the blink and the engine has been running on the battery only.
Wont start - bad gas? Torque454 Engine 16 03-02-2010 08:38 AM
carter carburator help needed/also hard start at times gmmahieu Engine 2 02-12-2010 12:36 PM
87 Bronco doesn't start kgm656 Engine 2 05-30-2006 03:00 AM
Not able to start warm customline from 1954 239 cid OHV V8 sapperdijoosia Engine 6 01-26-2006 02:39 AM
Welding Question?? Scratch Start?? 1931 steve Garage - Tools 3 01-05-2006 07:52 PM
