305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2008, 09:34 PM
my malibu 305 smokes all the time but the oil is clean and dont lose water. what could be my problem.
Old 02-12-2008, 09:35 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What color is the smoke and does it smoke at idle, WOT?
Semper Fi
Old 02-13-2008, 08:52 AM
is there oil on the bottom side of your breather lid ?
if so clean out the pcv line and make sure its not clogged at carb or throttle body
Old 02-13-2008, 09:37 AM
life is a temporary assignment
Your return hole's on your head could be plugged up.Or your valve stem seals could be bad. Or both.
Old 02-13-2008, 11:15 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Along with the other possibility's, you could have
a bad modulator allowing oil/fluid to enter the
vacuum line & then into the engine, I've only
seen this twice though, & one of them was a
corvair.
Take care,
Rich
Old 02-13-2008, 03:36 PM
Originally Posted by richard stewart 3rd
Hi,
corvair.
Take care,
Rich
I have seen that before too.Just unplug it at the trans in you will be able to tell.
Old 02-15-2008, 08:35 AM
the smoke is white and when im warming it up and hit the gas its black. i know that is the carb when its black.
Old 02-15-2008, 08:40 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If the white smoke is constant, after warmup, I'd look for coolant issues, blown head gasket, cracks, something allowing coolant into the combustion chamber. Black smoke when warming? If it's only during warmup when you goose it, probably the choke setting, rich, combined with the accelerator pump shot.
Semper Fi
Old 02-15-2008, 08:51 AM
been having this car since 95 and my sister drove it before i did in college same engine with no internal engine problems. might need to let somebody at a shop look at it and see whats up.
Old 02-15-2008, 09:40 AM
HawkZ28's Avatar
I know Victoria's secret....
White smoke at warm up could also be condensation in the exhaust burning out.
Is it constant- after long drives, car is warmed up, etc?
Old 02-15-2008, 11:09 AM
Now, already said what?
That it's constant?
That after a long drive it smokes?
It smokes only when warm, or after warmed up?
Old 02-15-2008, 01:55 PM
all the time. not real heavy but it smokes all the time. got a smell to it also.
Old 02-15-2008, 02:10 PM
lookatme's Avatar
what KIND of smell? need SPECIFICS. is it sweet like antifreeze, rich like gas?
you might think about pulling the spark plugs to see whats going on.
Old 02-15-2008, 02:36 PM
bondo's Avatar
Ayuh,...... I think that's the Answer,..... Right There...........
Old 02-16-2008, 12:02 PM
sweet like antifreeze.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
dirt track 305 groomer Engine 12 04-20-2008 02:46 AM
mild performance out of a 305 77formula Engine 4 10-23-2006 08:57 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
Where is my 305 from?? Is it a ligit Chev Engine frankthetank Engine 2 10-25-2003 10:49 PM
