Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305
Thread: 305
Old 02-10-2013, 11:43 AM
327NUT's Avatar
327NUT 327NUT is online now
No 160 psi is not 11.1, you need to get all your engine specs and use a compression calculator to figure your compression out. That will come later when all the machine work is done. If it's a basically stock engine rebuild with a cam etc. you may have "around" 8.50 - 9.0 to 1. There are lot of variables involved.... all depends on heads and machine work. ..... and your English is just fine.
