Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305
Thread: 305
  #34 (permalink)
Old 02-13-2013, 10:51 AM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by Wezz View Post
Oke .. If i will take the pistons uit .. Can i let it bore and buy a stroker kit? What kitt wil you recommend . Wil it work with my cam and stock portef heads .. Will i get more hp ?
Its a 305! Just do it the way you planed The horse power will surprise you. If you pull the pistons make sure everything goes right back where it was removed from!!!! And stagger the ring gaps when reinstalling the pistons! If it was me I would Mike the bores if they don't have much ware ! Have it deridged and honed, install new file fit rings and install new main and rod bearings! And your engine is fresh with no worry's! if you pull the pistons one at a time only, clean them good! Do not use a wire brush and reinstall them staggering the ring gaps you will be fine!
Jester
