i readed a lot of discus over about the swirlramp removal .. so i decide to one smooth him
here a better view
http://imageshack.us/a/img845/791/1022013521.jpg here the cill wall where i talked about
Hmm where that swirl heads? They look different than mine
bot how is the condition of the cylinder walls like you see in the picture
Wezz!
In the pic of the cylinder it doesn't look like they were honed? Did you install new rings? Did you have the pistons out? Or are you just installing a cam kit and heads? Jester |
Jester |
hello no i didnt get the pistons out .. like i said its my first project so onley the heads ported and new cam .. and clean up everything.. if you feel on the edge of the cylinder wall you can feel a little ridge on it .. but onley the dark ridge .. its not much and by looking the piston isnt touching it at all..
i looked a few days ago on the internet and I found a few pages that says that an interference fringe an accepted phenomenon .. but what will happen when I let it sit there is not a scratch or feel visible in the cylinder wall .. there was on that edge a little black attack like the pistons .. I HBE and edge gently cleaned the pistons also schooingeborsteld .. I have the pistons leave because this is my first project and I still do not know everything and I piston rings and bearings risky find .. mn engine has basically always nice run. but had a leaky koppaking. and did only what cylinder machining done and everything cleaned e camshaft replacement for others |
Is it bad to only instal a cam kit .. The cylinders had a good compression ..
No its not bad! Its done all the time! What did you clean your pistons with?
Jester |
Wits o Steelbrush. And putted cardboard in against the cyl walls. So i dont schratch them .. Good ?
Jester |
| Carb'd 305 to TPI 305, help? | coolerow | Engine | 2 | 09-23-2003 03:10 PM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
| 283 w/305 heads. 305 head gasket? | malibu65ss | Engine | 2 | 01-16-2003 02:07 PM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 1 | 10-14-2002 11:48 AM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 0 | 10-14-2002 10:10 AM |
