Wezz: We aren't used to working in MM convert your readings to inches and post the paper with your readings. Get a pencil and paper write down the measurements of each cylinder tightest to largest dimensions from bottom of piston travel to top you will have several readings for each cylinder! Measure your pistons and see how much wall clearance you will have at the tightest position of travel! I think you measurements are off? By my calculations. remeasure them again!
Or your tool needs to be calibrated! Take your tool to your machine shop and have him check it against his! Is your small dial working It seems to be stuck on the .002mm LOL Jester Check your bore gauge with a mike like in this video. Stock Bore is: 3.736 in or 94.8944 mm 305 Production: 1976–2000 Displacement: 305 cu in (5.0 L) Power: 130 hp (97 kW)-250 hp (186 kW) Bore and Stroke: 3.736 in × 3.48 in (94.9 mm × 88.4 mm) MOTOR SIZE....... BORE........ STROKE V8 - 305........... 3.736........ 3.48 |
Hi i did that . It was a few hondrerds to large @ some places . I let the pistons in and finish the block . Overbore is more expensive as a 350 block !
and my compression was good If you look good you can see a little hone schratches . So so bad it isnt right!?
How much tolorance. Can it have btw?
I convirted 0.500 mm to inch and came out 0.0196850393701 " is that much?
I mean . I convirted 0.05 mm to inch and came out 0.00196850393701 inch
Jester Cylinders are probably good if you can see hone scratches! If it ran good before you pulled it, it will probably be fine! just assemble it! and break the cam & lifters in! The only thing I wondered was if steel bristles got into the ring lands from the wire wheel you used to clean the pistons while they were still in the bore!
Ooo im so happy with this treat jester . Nobody can tel me or it was good or bad. You r i verry good man
i will get the lost wirewheel wire out . With air. Vacuum cleaner and a magnet ![]() butt the marzipan still not arived??? If its coming not to your house i will pay you with paypall if it comes i will suprise you
Jester |
Ok we stay holding contact haha . Do you knoe anythibg about a lock up conveter?
Your stock convertor is fine for your build!
Jester |
Haha i know but its for an friend of mine he has a 383 i pud a treath in category transmission
| Carb'd 305 to TPI 305, help? | coolerow | Engine | 2 | 09-23-2003 03:10 PM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
| 283 w/305 heads. 305 head gasket? | malibu65ss | Engine | 2 | 01-16-2003 02:07 PM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 1 | 10-14-2002 11:48 AM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 0 | 10-14-2002 10:10 AM |
