305 350 gasket sets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 11:08 AM
305 350 gasket sets
new here but have a quick question,can 350 head gaskets be used ok on a mild street driven 305. Seems to be a big difference in price between 305 and 350 gasket sets and the only difference i can think of is the head gasket bore size. thanks gord
Old 03-06-2006, 04:10 PM
Anybody any thoughts on the problems of using the 350 gasket sets on a 305. thanks gord
Old 03-06-2006, 04:34 PM
Yes, like you said the bore size is different on 350's but the rest are all interchangeable except something like centerbolt valve cover gaskets.
Old 03-06-2006, 04:47 PM
King of my Man-cave.
There will be a small loss of compression with the 350 gaskets on the 305 and there will be some unburned hydrocarbons in the area where the gaskets differ. Personally, I would use the 305 head gaskets. After all, I'm sure that GM could have saved millions of dollars by using the same gasket in both, but they didn't.
tom
Old 03-06-2006, 05:26 PM
I wouldn't interchange head gaskets but the REST of the gaskets you could (intake, water pump, distributor, exhaust, etc....)
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
1991 Firebird: Conversion from 305 to 350 Chevy21 Engine 6 03-22-2005 12:28 AM
350 Heads on 305? JohnyR17 Engine 6 01-05-2004 08:53 PM
305, 327, 350 which one is better Jessab Engine 15 11-15-2003 04:14 PM
305 vortec heads on a 350 tonylsg Engine 13 09-21-2003 05:54 PM
