Thread Tools Search this Thread share on Facebook
  #1
Old 03-13-2009, 01:49 PM
russellu russellu is offline
305 to 350 Parts swapping
My Grandson is swapping out a 305 sbc in his 86 pickup-C10. He is installing a 350 sbc. Just what 305 parts are interchangeable on the 350?
1. Distributor?
2. Transmission?
3. Harmonic balancer?
4. Carburetor (quadrajet 4bbl)?
5. Any other hidden problems lurking that I should know about.
Thanks
Register now (free) or login to remove ads
Old 03-13-2009, 02:29 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
All of them are....A 305 and 350 are identical externally.....just the bore and stroke are different.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 03-13-2009, 03:39 PM
user151's Avatar
user151 user151 is offline
title.......
Might get more response to your posts if you read this
Read Me: Please title your threads correctly.
Old 03-13-2009, 04:58 PM
sam-missle sam-missle is offline
stroke is the same, just bore is different.
sam-missle
Old 03-14-2009, 03:36 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
hi there welcome to the forums.,
everything swaps,
down to the bare blocks,
especially '80-'85(minor changes in 80 such as oil stick moved to other side of the block and is different length)
and in '86 up there was a crank and seal change.
the flexplate/flywheel wont swap between 85 down and 86 up
different crank flange pattern shape
86 up is smooth round crank end with a new one piece rear main seal
'85 down is large flange type with the old two piece rear main seal design
so if the 350 is an 85 down then you will have to get another flex plate or flywheel, one from an '85 older v-8, or old L-6 engine such as 230, 250, or 292, etc.
good luck
Old 03-14-2009, 07:29 PM
Plaintoast Plaintoast is offline
1. Distributor?
2. Transmission?
Thanks
Most of what you've read is correct, but unless you also change the timing chain cover, don't try using the stock harmonic balancer, they are different.
Old 03-15-2009, 02:24 AM
DoubleVision's Avatar
DoubleVision DoubleVision is online now
Socially Unsociable
Since it`s a 86 is the computer going to be used or has it been bypassed?
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "305 to 350 Parts swapping"
ThreadThread StarterForumRepliesLast Post
ARE 305 and 350 VORTEC HEADS SAMEbadriandEngine3904-06-2011 08:40 AM
305 head on 350savman1Engine410-15-2006 09:18 PM
From a 305 to a 350From87to88GTAEngine410-26-2005 09:53 PM
Will chevy 305 HO heads fit on a 350?sugarmonkeyEngine501-16-2004 07:07 AM
305 exhaust on 350 block help can it be donejackfrost51Engine203-12-2003 05:44 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
