305 or 350 SBC heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2013, 07:47 PM
31 five window
Last journal entry: grill and rear end
I have a 1991 305 TBI with a burnt head gasket.Head # 14102187.I have a set of 350 heads #10239906.Which would be best to rebuild for dependability?This is just a daily driver,high performance doesn't matter unless the best head happens to do both.Thanks in advance.
Old 04-11-2013, 08:26 PM
BOBCRMAN@aol.com's Avatar
Have the 305 heads done and milled flat. The other set will require more work $$$$ and intake manifold.
Old 04-11-2013, 09:25 PM
31 five window
Please explain.The 305 is a 1991 and the 350 is a 1996. I didn't check but I thought they had the same intake pattern.Or are the 350 heads Vortecs?
Old 04-11-2013, 09:46 PM
Yes the 350's are Vortec and have larger chambers.
Old 04-11-2013, 10:22 PM
31 five window
Thank you very much,I just remembered they are Vortecs,but I didn't know they had bigger chambers.Thanks again.
Sbc 350 w/ 305 heads.. kingofny1997 Engine 13 04-14-2013 09:11 PM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 11:21 AM
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 10:48 PM
SBC 305 Heads on a 350 ???? Brawler Engine 0 07-15-2007 05:03 PM
350 sbc..305 heads?? learjet60 Engine 6 01-28-2005 09:28 PM
