305/350..what do you think????? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-01-2008, 03:26 PM
Originally Posted by curtis73
As a general rule, "bigger" parts means bigger HP, but it means it shifts the power up in the RPMs. Bigger cam, head ports, compression, carb, intake, etc... it all has to be matched. The nice thing about bigger engines is that you can get that bigger power without shifting things up in RPM.
A stock TBI engine (which is what I assume you have) has the tiniest of everything; tiny cam, heads, TBI (carb), and tiny displacement. They were done that way basically so the vehicle had a means of moving around; not much power, but great on emissions and MPG.
When we talk about upgrading an engine for more power or torque, we are basically banking on the fact that the factory made very mild engines. We can put some slightly "bigger" parts on it and get nice power upgrades without putting the power too high in the RPMs. Factory engines typically use parts that make it suited for low power from idle to 4500 rpms. Street engines use head, cam, intake, and carbs designed for 1000-6000 rpms. Race engines use bigger parts and usually don't make power until the 3000-7000 area. The ticket is choosing the right "bigger" parts so that you match the target use with your desires.
On the street, size is king, so a 350 will be much easier to get your power goals without revving to the sky to get it. Then you fine tune it depending on your use. A performance truck that sometimes tows a boat? You're going to want to keep it on the mild side of that 1000-6000 rpm range. A light-weight Camaro that only gets driven on the street on the weekends? You can get away with a lot more.
The other thing to think about is the rest of the vehicle. You can modify a stock engine a little bit without changing the rest of the vehicle, but keep in mind that torque converter stall, transmission gearing (and strength), rear axle ratio, tire size, traction, rear axle strength, and a whole host of other things come into play. For instance, in that truck, chances are it has a monster rear axle with 4.10 gears already, but the Nova might have a wimpy 7.5" rear axle with 2.73 gears. The more power you add, the more you have to modify the rest of the car to match it.
But... most mild street performance can be dropped in place of a factory wheezer without too much modification.
Sorry Curtis, didnt see your reply!!! Didnt mean to step on your toes...
  #17 (permalink)
Old 10-01-2008, 03:40 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
No toes were harmed during the formation of your post
  #18 (permalink)
Old 10-01-2008, 04:50 PM
stepside454's Avatar
305s arent as forgiving to overly larg camshafts, or carburaters. when "hopping " up a 305, you have to stay pretty coservative, or youll kill what power it does have. a rumpety cam in a 305 would be an RV type cam in a 350.'
As far as MPG, in some cases a 350 gets better MPG than a 305. depends how its used.
  #19 (permalink)
Old 10-01-2008, 04:59 PM
im putting the 350 in a chevy caprice 91'.....the guy got the 350 from a police intercepter, he said it was a roller motor...i took the valve covers off and there is no roller rockers at all....kinda mad, i am also getting a posi rear end, im not sure the gear ratio....i have a 305 in it now and i want to put the 350 in and be impressed....my 305 runs fine now but i dont think it has much compression at all.....the 350 we tested, and at idle it had 70lbs. of oil pressure...i think thats good....i have time...i can save the money i just want to do things right the first time and make sure i can get as much out of the 350 as possible. my caprice's computer is all set up for tbi.....i want to know what i could do to keep the tbi, but upgrade so it will be better....i dont know what to buy or what would be good for this......Thanks everyone for your advice and help
  #20 (permalink)
Old 10-01-2008, 05:08 PM
curtis73's Avatar
Wiki Edits: 16
"roller motor" means the cam, not the rockers. GM didn't use roller rockers on any of their motors.
  #21 (permalink)
Old 10-01-2008, 05:19 PM
i have some pictures of the block numbers....on the back its 1493638.....and i have pictures of the other longer number.....i dont know if anyone could maybe find out the history of this motor....
http://i116.photobucket.com/albums/o...4/DSC03332.jpg
http://i116.photobucket.com/albums/o...4/DSC03337.jpg
http://i116.photobucket.com/albums/o...4/DSC03340.jpg
http://i116.photobucket.com/albums/o...4/DSC03341.jpg
if anyone could help me maybe find out what this motor is capable of i would appreciate it....thanks everyone
  #22 (permalink)
Old 10-01-2008, 05:25 PM
PutPut72's Avatar
Earplugs are in the glovebox
The bigger the better, Don't build a 305 its like the Bast@rd child of Chevy performance. Also, if you do a 350, why not make it a 383? Look in Summit or Jegs and you can purchase complete stroker kits for around $850. Might as well if you have to have machine work done to the reciprocating assembly.
Harmonic balancer 305/350 Eric64 Engine 6 08-20-2005 11:03 AM
305/350 Myeyeslookmean Hotrodding Basics 9 09-28-2004 08:36 PM
305/350 flywheel chevyman06 Engine 1 06-03-2004 09:46 PM
305/350 how to tell the diffrence 85 chevy p/u Engine 3 01-03-2004 02:49 PM
305/350 crankshaft bcw Engine 9 12-07-2003 09:23 PM
