Thread Tools Search this Thread share on Facebook
  #1
Old 08-23-2005, 08:38 PM
BigDawgsEatFirst's Avatar
BigDawgsEatFirst BigDawgsEatFirst is offline
400SBC4Life
305 Balancer on 350 ? timing marks off the chart
If a guy has a 305 Balancer on a 350 engine
with 350 timing marks
when we time it the marks move toward water pump
the timing marks for a 305 are read from top of water pump right
what the heck is going on
has anyone ever seen or done this
Register now (free) or login to remove ads
Old 08-23-2005, 08:44 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
If you are using a different balancer, you should always check for TDC on it. ....Heck, I even have found that the stock balancer mark has been out a bit.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 08-23-2005, 09:07 PM
KNanthrup KNanthrup is offline
There are a lot of different balancers. I went through the same process. Some were timed TDC from the top below the water pump and others from the side. You will find that it will be different even with same sized balancers. You have several options, either change the TDC mark yourself on the balancer and relocate or you can find the correct balancer.
In any case, as mentioned, it's ALWAYS a good idea to double check TDC with your balancer. Finding the right style balancer is simple by checking the spline groove to TDC cut.
Good luck
Old 08-23-2005, 09:13 PM
400SBC4Life
Do u know who sells a piston stop or a link to make one
thanks
BDEF
Old 08-23-2005, 09:16 PM
Are you talking about a spark plug stop or head-off stop? for plug stop, bought mine from jegs. if you cant find it ill search for it and link it but should be easy to search. plug stop you have to be very careful with though, and turning the engine backwards is a pain cuz you cant use the balancer bolt. keep that in mind
Old 08-23-2005, 09:21 PM
poncho62's Avatar
Wiki Edits: 5
I just hollow out a plug and weld a bolt through it.............works great.
Ontario Rodders
Old 08-23-2005, 09:33 PM
400SBC4Life
Thanks, for all the super replys
I guess when I stop learning new things
I will be dead
Old 08-23-2005, 09:35 PM
I will be dead
Haha tell me about it. I just tore my engine apart and re-assembled it with the same parts and STILL ran into complications. Sometimes it's a never ending battle, but it's always worth it in the end if you do the job right.
Old 08-23-2005, 09:38 PM
baddbob baddbob is offline
The piston stop method works fine, put the stop in and rotate clockwise by hand till she stops then make a mark, rotate counterclockwise till she stops and make another mark, TDC will be exactly between the two marks. Pull all your spark plugs out so she turns easily. Bob
Old 08-24-2005, 02:15 AM
400SBC4Life
Thanks for posting
Old 08-24-2005, 12:33 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Yep, easy to do.
Old 08-24-2005, 12:56 PM
1982 SS's Avatar
1982 SS 1982 SS is offline
Flamethrower
Last journal entry: More Cooling fan pictures.
The 305 timing is read from the top of the water pump. 350 is where you were trying to check it from. If memory serves me, you would wind up with somehting around 60° at the 350 mark. Get a 350 damper and it will be a better damper than the 305.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "305 Balancer on 350 ? timing marks off the chart"
ThreadThread StarterForumRepliesLast Post
Distributor Tuning and Theory - Part 1Rick WIEngine3504-26-2011 12:38 AM
Port or Full time vacuumcool rockin daddyEngine12910-05-2010 03:00 PM
Weiand Timing Cover and Harmonic BalancerRoadsireEngine807-02-2005 07:30 AM
Chevy 350 Timing issuesDans83OldsEngine309-04-2003 02:22 AM
72 chevy 350 timingsteveschEngine409-01-2003 08:05 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
